Go to Post Building a drone during Ri3D is going to be a challenge... - Ginger Power [more]
Unread 16-10-2014, 20:25
Re: Vision Processing with Raspberry Pi
Originally Posted by jman4747 View Post
The R-PI UART pins should plug directly into the RoboRio MXP ports' UART pins. I don't know if level shifting is required between those UARTs. On the CRio you need to plug the R-PI UART into a RS-232 to UART converter. Conversely you should try to look at what you can get away with by using just GPIO. Just remember you need to use some sort of level shifting between the R-PI and CRio/RoboRio GPIO.
The roboRIO serial port on the main board is RS232 levels. The serial port on the MXP is LVTTL levels (5v compatible).
