CNC Aluminum: Recommended Speeds/Bits?
We've had limited success using our CNC router with aluminum. Anyone have recommended settings for pass speed and spindle speed, as well as recommended cutter types? Thanks!
Re: CNC Aluminum: Recommended Speeds/Bits?
It really does matter what exactly your CNC router is...but....
Single flute and you can go move fast as long as you balance that speed with: the proper spindle speed, cut depth and machine rigidity. There are speeds and feeds calculators and charts. I do not want to recommend a specific speed because you did not provide enough information to understand the implications. |
We just got a CNC Router this past Sept and started cutting Aluminum with some success starting last week.
Last night we made custom drivetrain plates from 3/16" 6061 Aluminum. We have been using a 5/16th end mill while waiting for our shipment of Onsrud G1817076 Upcut Spiral O-Flute and G3168471 Straight O-Flute bits. Spindle Speed - 10,000 RPM Feed Rate - 20 IPM Plunge Rate - 10 IPM *Make sure you have coolant. We are using a spray system with a vegetable base spray. Let me know if you need anything else and good luck |
What machine do you have?
Sorry, we have a Techno Isel 31" x 33" Servo Gantry with a 5HP 6000-18000 router. We also have the vacuum table setup.
What problem are you having cutting aluminum: Deflection? Chip welding? Stalling? |
#7
-Ronnie |
#8
it's a 220 three-phase. Maximum speed is 400"/min.
#9
Also, we have no coolant. Which could be a problem, but it's primary use is wood and plastics, and with the vacuum table I really don't know how we'd make a coolant delivery/extraction system work.
#10
Okay with 5HP at those RPM and your possible feedrates you are probably running into the coolant problem as has already been discussed.
If you cut slow and shallow enough with a single flute like you would on a manual mill you can probably cool it by hand but that's a drag. Be warned there can be such a thing as too slow. You don't sound like you have an enclosure so flood coolant would spray vegetable oil all over to go rancid later (not to mention be sticky, slimy and a hazard). Mist coolant might be a good option. The flow is slower so you won't just get it in the face like a water gun. You will likely still have to slow down from the speeds you could get with proper flood coolant. Also you probably want to hang a curtain to contain things. Still less involved than a box, gutter, chip auger, collection tray, filter and big pump. Look at something like the KoolMist (this is neither my assurance it is the perfect solution nor a product recommendation just a suggestion). Just for Maker fun: https://www.youtube.com/watch?v=bTRuDzdezbg Still would like to know what the actual problem was you were seeing while doing aluminum. Last edited by techhelpbb : 17-10-2014 at 12:45. |
#11
We got a Camaster Stinger 2. 1.7 HP HSD Spindle 900 oz- Nema motors Mister System Phenolic Top Couple of other goodies. |
#12
Step 0 with any CNC machine (IMO): get GWizard. Life will suck WAY less. It even has rigidity models, which will help guide your feeds and speeds by de-rating power on less-rigid machines like routers.
Here is a blog entry from the guy that makes GWizard. Worth a read. Then a re-read. Then another re-read after you try some of the suggestions. http://blog.cnccookbook.com/2012/03/...tting-success/ Quote:
Are you at least running a serious air blast to make sure chips are not being re-cut? If neither of these then I think I know your problem... |
#13
GWizard is useful. Otherwise you can look up how to do feedrate and spindle speed calculations online.
As far as what you need, you're going to want a 1/4" single flute onsrud end mill. You also want a mister. This thread is great. |
#14
As others have said, Onsrud bits are the way to go. We use a .125" single flute end mill designed for cutting aluminum, and we can go about 100 ipm comfortably through .125" aluminum.
We haven't had much luck with our vacuum table as a reliable hold down. Instead, we like to use a combination of double sided tape and clamps on the edges of the material. The mister has a tendency to saturate the air in your shop with coolant, which smells strange, and probably isn't very good for long term exposure, so we've just had somebody with a spray bottle spraying some coolant (mobilcut 102) ahead of the bit. To clear chips, we've just zip tied an air line to the side of the spindle that points right where the cutter enters the part. |
#15
Highly recommend the Onsrud single-flute cutters as well. We use them religiously in our lab on our CNC router. We run .125" to .250" diameter cutters depending on the parts
We use a Unist mister and coolant setup on our router, and are very happy with it. It periodically deposits a mist of coolant, and it doesn't seem like very much of it aerates. I don't ever smell it. I haven't noticed any changes to the environment/air since using them. We run 4 of the mister units in a very small workshop on our lathe, cold saw, manual mill, CNC router. All the mist seems to end up on the workpiece and machine (not in the air), and clean-up is a simple wipe down. |
