Go to Post The Chairman's award is about doing what you can to strengthen the FIRST community. It doesn't require money to simply lend tools, wise advice or a hand. - Koko Ed [more]
Unread 08-10-2014, 12:06
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
roboRio / LabView 2014 compatibility
This question is mainly directed at beta testers... We are considering pre-ordering the new roboRio from AM to have it in early December in order to get familiar with it ahead of kickoff. We are using LabView and I am wondering if last year's version of LabView will recognize the roboRio and generate proper code for it or if there is an update we need to install first.
Unread 08-10-2014, 12:12
Re: roboRio / LabView 2014 compatibility
You won't be able to use the roboRIO hardware until you get the software released in the Kit-of-Parts at Kickoff.
Last year's software won't work.
Unread 08-10-2014, 12:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
It is still worth buying a second system if your team can afford it. The would include the PD board etc. You can pre wire it so when you get the software (Kick Off?), the programmers can hit the ground running.
Unread 08-10-2014, 21:10
It is up to you as to whether you need the HW, but to confirm, the 2013 SW will not target the roboRIO. On the other hand, the 2013 SW will work on the PC, both for basic programming and for robot programming in the simulator.
Also, the LV2014 SW is available in eval right now. If the updates are made available before kickoff, then you will be golden. Only FIRST knows when stuff will be made available, though. So, it may not happen until kickoff.
Greg McKakle
Unread 09-10-2014, 08:00
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Just to be clear:
LabVIEW for FRC 2014 is based on LabVIEW 2013 and will not work with the roboRIO.
LabVIEW for FRC 2015 is based on LabVIEW 2014 and will work with the roboRIO, but has not yet been released.
Doug Norman
Unread 10-10-2014, 17:13
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Just curious, Will LV for FRC 2015 work with the cRios?
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
homepage: newulmrobotics.com
Unread 10-10-2014, 17:24
The FRC 2015 LabVIEW can be used to develop code for the 4-slot FRC-cRIO II's, but not the older 8-slot.
To use the 2015 LabVIEW software on a cRIO, the cRIO must be reformatted to use image v54 or later (it'll come with the Kickoff software release).
Unread 10-10-2014, 22:56
FRC and FTC Mentor
AKA: Adam Miller
Darn. We have the 8 slots and we have 2 of them!
Adam Miller
Unread 11-10-2014, 09:15
The LabVIEW code isn't that different for the 2014 season and the license we have for that is not time limited.
You can still use that on the 8-slots into the forseeable future.
We might not want to mix the two LabVIEWs on the same PC, though I haven't tried it yet myself.
Unread 11-10-2014, 13:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You can mix but you'll run into problems if you open by double clicking the project file. You'll need to open the version you need and then open the robot project.
Unread 13-10-2014, 09:10
I would suggest not installing FRC 2015 (when it is released) on a machine that still has FRC 2014 installed. LabVIEW for FRC 2015 will likely overwrite some 2014 files. While it may work, we will not be testing or supporting this installation combination.
We are expecting you use a different computer for FRC 2015, or that you first uninstall LabVIEW for FRC 2014.
Doug Norman
Unread 18-10-2014, 20:11
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Doug
Did I hear correctly that our 8-slot is a brick? Was not from you, but inferred by another poster. The FRC2014 LabView license runs out in January, and the FRC2015 LabView will not support it?
Software Mentor
3853 Pridetronics[
Unread 18-10-2014, 20:24
The 2014 SW isn't supposed to expire. And though I haven't tried, I assume the 8 slot can be targeted. But you will run out of memory if you do too much in the code.
Greg McKaskle
Unread 19-10-2014, 19:04
Tim
FRC #3853
Greg McKaskle
Thank you Greg.
I had an old memory of other seasons when the previous years' license gave up in early January. FRC2014 really does not expire. Thank you very much NI.
Does NI Linux RT run heavier on memory than it's predecessor?
I am warned. We'll be happy if we can run a cereal box with it, so good enough.
Tim
Software Mentor
3853 Pridetronics[
Unread 20-10-2014, 07:05
Greg McKaskle
You won't be able to target an 8-slot in LabVIEW for FRC 2015. The NI-RIO driver will no longer support it.
But yes, you will still be able to use your 8-slot with LabVIEW for FRC 2014, since that license will not expire.
That said, I expect FIRST will require the roboRIO for 2015 competition.
Doug Norman
