Go to Post We also use CAD heavily. Cardboard Aided Design. Which is considerably more accessible and intuitive to most students than the other CAD. - JamesCH95 [more]
Unread 20-10-2014, 08:10
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Battery Connector Color
Our team's charging station is built on a library cart, with the charger on top, and the batteries down below. It charges 8 at a time, and the wiring gets hard to follow. To make it easier to identify which battery is which, I want to put different color Anderson SB50 connectors on. But the colors are not compatible with one another. This means that we would need a bridge between the battery and the robot that changed colors. I don't want to do this because there is a higher chance of a bad connection, so my idea was during competition, we would change the connector on the robot to match the battery color. Have any other teams experimented with this?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 20-10-2014, 08:30
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Battery Connector Color
Why not wrap the connector in different colored tape? Or paint them all white and put big numbers on them?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 20-10-2014, 08:31
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
A simple solution is to use a different color of electrical tape that is attached to the charger in a visible location and then the same color of electrical tape on the Anderson connector of that changer. Really simple, just follow the color trail.
Unread 20-10-2014, 08:39
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We ordered a dozen red SB-50s and received a dozen grey ones. When we went to plug them in they didn't fit. We just milled down the connector where there was interference and red plugs into grey just fine now. The contacts are what holds them together anyway. I'm not positive about other colors, but contact position should be the same on all of them. You can see our setup here.
Otherwise, what about organizing your wiring a little better so it is easier to trace? Or labeling your ports on the charger and then labeling you battery positions? In the above linked picture, we had a hard time figuring out how we wanted to organize things, but ended up with a visual layout. The batteries are arranged top to bottom by number and on the charger they go from the middle to the out side by position. You can see how 9 and 10 are not lit up on the charger because they aren't in the cart. If we unplugged battery 1 on the bottom left it would turn the light off on the far left side of the charger.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 20-10-2014, 09:17
ArchdukeTim
We have electrical tape on them now, and it looks god awful, it peels off, and we don't have 8 different colors. However, we DO have 8 different-colored connectors, and nothing else to do with them. The main reason I want to change the battery color is so they don't go to waste. What about other ideas about what to do with them?
Unread 20-10-2014, 09:40
If you just put a small piece of electrical tape on a plastic connector, it is likely to peel off. But if you use the tape as it is designed, wrapping all the way around so that it is stuck to itself, it will stay on for a very very long time.
We also don't have 8 different colors of electrical tape. However, we do have a color printer, and we have nice strong clear tape. Our chargers' connectors are labeled with well-taped paper numbers and colors, with matching paper color collars on the wire and matching numbers and colors on the chargers.
Unread 20-10-2014, 10:23
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Color heatshrink. Cheap from online, it makes a good, protected connection, and it is good protection. Just put it on before the connector, where the wire goes into the connector. That way its right by the connector so if it ever becomes unplugged, it can easily be recognised as to what motor or whatever it goes to.
Unread 20-10-2014, 10:44
ArchdukeTim
Do you have a picture of what the connector looks like now that it is milled?
Unread 20-10-2014, 10:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
or you could dress the wires, to make them easy to follow.
Unread 20-10-2014, 11:33
I'll have to take one when I can get back down to the shop. But just imagine the part the arrow points to in this picture cut down 1/8".
And no that isn't my picture, I borrowed it from google. We haven't managed to fry an SB-50 yet.
Andrew Basse
Unread 20-10-2014, 14:00
AdamHeard's Avatar
Lead Mentor
I interpret the rules to say that the connector has to be that PN, which means red only.
So all the batteries and the robot itself must have a red connector. My as well then use red on the charger as well, and label/color via some other method.
Unread 20-10-2014, 14:28
ArchdukeTim
Which rule is that?
Unread 20-10-2014, 14:35
AdamHeard's Avatar
Lead Mentor
Which rule is that?
R35 in 2014 calls out "SB50". I could be mistaken, but I believe only the red has SB50 as the PN, and the other colors have another letter at the end to denote color (EX, SB50G).
Unread 20-10-2014, 14:37
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Which rule is that?
Actually, the 2014 rules don't specify a color. All R35 says is " Anderson Power Products (or APP) Connectors (p/n SB50)", which is available in multiple colors, but different colors don't mate (except for black and grey).
I'm fairly certain that, if asked, the 2014 GDC would have said that only the red connector is allowed, since part of the reasoning of a single connector is to allow all batteries, chargers and robots to be interchangeable across teams.
Unread 20-10-2014, 18:43
ArchdukeTim
Makes sense. Well, I think we are going to bag the idea, but if anyone has an idea to make use of the 80 or so connectors we have, please share.
