Thread Tools |
Rating:
Display Modes |
Re: Motor suggestions for rubiks cube scrambler
Attach Arduino Mega to RAMPS shield. If you need data storage use SD card shield (maybe boot load from it). If you want an interface attach an LCD or touch screen shield. These are all parts often used to build RepRap printers. When used as a printer you can tether the printer with USB (emulated serial) or use a SD card to standalone. The Arduino provides the USB connection and the SD card shield is obviously for the SD card. Program the Arduino yourself instead of using a G/M code interpreter that would usually read the G/M code from the card when this is used to be a RepRap printer control. The platform is still Arduino underneath. http://www.makergeeks.com/a4stmodrmo.html http://reprap.org/wiki/Arduino_Mega_Pololu_Shield http://reprap.org/wiki/RAMPS_1.4 - Test code at the bottom. Please be aware that the test code uses the Arduino digitalwrite function which is fast enough but there are faster ways to toggle Arduino pins. Last edited by techhelpbb : 20-10-2014 at 11:54. |
In an attempt to help you navigate the thicket of material you will probably find written about this, and similar subjects, I'd like to point out something.
I think I'm correct when I say that "servo" is a *use* for a motor, not a type of motor. All sorts of motors (including stepper motors) can be used to implement a servo function. If you keep this distinction in mind, it will probably save you a lot of grief as you wade through what has been written by folks who didn't know about the proper use of the term "servo" (and who enthusiastically mix apples with oranges when giving advice (they are trying to be helpful, but ...)). Blake |
