Go to Post I didn't say this! - Max Lobovsky [more]
Unread 20-10-2014, 12:48
Amit3075's Avatar
Amit3075 Amit3075 is offline
Purple is the new black
FRC #3075 (Hadream Team)
Amit3075 is an unknown quantity at this point
Polycord stretchers
Hi guys,
In 2012, a lot of teams used polycord or strings connected between two rollers in order to lift the balls to the shooter.
So my question is... how can you keep the polycord stretched?
I thought of maybe connecting one of the rollers on a slot and then adjusting the distance between the two rollers... but I look for better solutions.
Thank you very much,
Amit.
____________________________________________
2010-2012 FLL Angry Bots #382
2012-Current FRC Hadream-Team #3075
Unread 20-10-2014, 13:02
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Polycord stretchers
We cut the polycord to roughly 90-95% of the required length (2x distance between pulley axles, plus one full pulley circumference [or rather, 2 halves]) It really depends on how taught you want your belts, by which trial and error is the best method.
It was not the easiest method, but we fused our cords while totally loose, and once cooled, stretched and installed the pulleys by hand. On our 2012 robot, we had between 5 and 8 belts on a pvc tube acting as a very wide pulley. We stuck one end into the bearing block, and used leverage to stretch all the belts at once until we could jam the other side into its block.
I would recommend not fusing the belts while under tension, as the whole process is about as frustrating as it gets. Perhaps some reasonable method exists, but none that I am aware.
The idea of putting the pulleys in a slot is a good one, provided you can fix the pulley in their stretched position.
Unread 20-10-2014, 14:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Quick Connect Round Urethane Belting is quite easy to handle. It has the downside of snapping once every competition if you don't check that the quick connects are seated every match. This downside is greatly mitigated if you pay attention to the minimum pulley size.
You can't tell this from the mcmaster site, but looking up the part # that's printed on the belt led to some spec from the manufacturer in 2012 that said 3% stretch is optimal for this particular cord. We measure the belt length using string, then divide by 1.03. Following mfr's spec with this belt is key to it success in FRC - an overstretched belt will cause extra load on the motor, just like a pulley that is too small.
Unread 20-10-2014, 15:42
Amit3075's Avatar
Out team is based in Israel, so we will search the stores for this item. Thanks!
Unread 20-10-2014, 16:27
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
McMaster also sells a Welding Kit for Urethane Belting which includes a unique clamp. This clamp holds both ends of the belt together while the belt is mounted on the pulleys. A modified soldering iron/plate is inserted between the ends (which melts both ends at the same time), then the iron is removed and the clamp squeezes and holds the melted ends together (note that while the belt is under tension, the joint is not while cooling/curing). After sitting sqeezed together for 5 minutes, the belt is supposed to be at partial strength and the clamp can be removed...just trim off the flash. The belt is at full strength in about an hour...or less in an emergency.
Please note that we did NOT pay the $700+ that McMaster charges...I don't recall where we got our kit, but it was about $100.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 20-10-2014, 16:49
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Like JesseK said, it is very important to use the manufacturer's data regarding belt length. Instead of using a welding kit we just melt both ends at the same time using a small butane torch and then press them together. The downsides to this method are that you won't be able to do it in the pit and it sometimes requires two people (an extra person to turn off the torch). To clean up the flashing, rolling the belt on a bench grinder works like a charm.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 20-10-2014, 20:10
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Originally Posted by Mike Marandola View Post
Instead of using a welding kit we just melt both ends at the same time using a small butane torch and then press them together. The downsides to this method are that you won't be able to do it in the pit ...
I've said it before and I'll say it again: avoid the use of open flame with urethane belts, the fumes are not good. Instead - why not use a heat gun? Works just a well, won't fume, and you can use it in the pits. Expose just the ends of the cord from behind a shield of scrap, the ends will melt like a marshmallow when they're ready to connect.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 20-10-2014, 20:20
Lead Bumper Mentor
AKA: Mike Marandola
Thanks for the idea, I will try it out. Are there not fumes from any method that melts the urethane at the same temp?
Unread 20-10-2014, 21:42
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Not necessarily. Flames will tend to cause chemical reactions and melting, while lower-temperature heat will mainly melt it.
A science lab hot plate (with a protective piece of metal on top) makes a good instant urethane melter for this application. I have never encountered objectionable fumes using that method.
Unread 21-10-2014, 23:50
VioletElizabeth's Avatar
VioletElizabeth VioletElizabeth is offline
AKA: ECD
FRC #1868 (Space Cookies)
VioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really nice
I seem to remember my team making a jig, placing the two ends of the cord in the jig, melting it, then clamping the top half down. This was my freshman year back in 2012 and I wasn't working on it, so my memory is somewhat fuzzy.
As for attaching them, it was the worst part of assembly, we had to get ratchet straps and get several people to make the polycord go on and I think we did it maybe twice, because it was such a pain we tried really hard to avoid it.
