Go to Post I can't think of a match where we didnt do the ritual. We always called it... "Deploying the code" - Briansmithtown [more]
Unread 22-10-2014, 02:04
Gary Suter Gary Suter is offline
FRC #2439
Gary Suter is an unknown quantity at this point
potentiometer code
How do you find values off of a potentiometer for an Andy Mark turn table? (what is the basic code for reading the values off of potentiometer?)
Unread 22-10-2014, 02:47
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: potentiometer code
What language? You use the center pin of the potentiometer to find voltage when you connect the other two terminals to power and ground (one to power, the other to ground). Then you map that voltage between the maximum and minimum voltage you can get from the potentiometer (turn it all the way one way and all the way the other way to find that) and that's how you get your angle relative to the minimum and maximum.
Unread 22-10-2014, 10:03
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Part of the beta testing has included a new potentiometer class. It's basically a wrapper around an analog input that lets you specify the degrees per volt (360 * #turns/5 volts * any gear ratio you want to take into account) send an offset, then read back the values as degrees.
It's really slick and works perfectly from our testing (Java). We used it for a swerve drive project, which let us plug the potentiometer object straight into the PID loop to control steering the modules, which worked great as our equations returned an angle to turn to-do we didn't have to do any manual calculation on the value to convert it to volts to get it to work.
2016: Lake Superior WFFA
Unread 23-10-2014, 16:39
Look at the AnalogChannl VIs/class.
