#16
Re: Sheet metal fabrication tools
A set of Cleco clamps go a long way to lining up rivet holes and keeping things square. Look on eBay for some great deals - everything to get started for about $50-75.
Grizzly is a little better on quality, but not the best. Import or domestic, it doesn't matter. Price and brand is more relevant to quality since the Chinese factories will meet the specified price point and make tradeoffs to meet schedule, demand, and specifications. Typical US importers want the lowest cost possible, and that's when quality lacks. Swag Offroad has a shop press brake kit you might want to check out (it may or may not meet your requirements - it does require welding). The Harbor Freight 20 ton shop press is about $160 on sale. I check Craigslist nearly every day for miscellaneous metalworking tools. Press brakes and shears are a rare item now that many fabricators have long-ago switched to large multi-ton hydraulic systems. Also, glad to see you are venturing into sheet metal! ![]() Last edited by protoserge : 22-10-2014 at 09:18. |
#17
Disclaimer: I'm no sheet metal expert, this is just what I've found over the years of general fabrication in FRC and FSAE.
One doesn't really need the shears or roller IMO. Straight cuts in sheet metal (and cuts considerably more complex that shears can do) can be made with a tool like an air nibbler and a clamped straight-edge. I've never felt the need to use a roller or bead roller (though we have both in our shop) and a CNC plasma cutter has all but completely supplanted the 4ft+ air-powered shears we have. If I were to be picking machines from scratch I would get a large CNC router table and the finger brake. Thinking about it... we may try using the bead roller this pre-season to see how we like it. Quote:
The advantage of a setup like this (vs a combo machine) is that broaching, pressing in bearings, etc are all now very easy to do. Though the longest possible bend has gotten smaller. Last edited by JamesCH95 : 22-10-2014 at 10:58. |
