Go to Post Our strong support is the result of 14 years of very organized "nagging". :) - OZ_341 [more]
Unread 20-10-2014, 23:12
wward2906 wward2906 is offline
FRC #2906
wward2906 is an unknown quantity at this point
Talking [FTC]: RobotC to legomindstorm NXT tetrix/matrix
If there is already a tread for this I have not found it yet so please refer. Otherwise...We, Team 5328, are trying to program our bot. So our version of RobotC was purchased for VEX and NXT platforms, BUT we do not have the NXT to Tetrix/matrix platform under NXT. EV3 is there with NXT, but when we select NXT there is no other platform. What the heck did we do wrong. I even decided to purchase a copy for home and it does not have the NXT - tetrix/matrix platform either. It seems that this is an ongoing problem in our school district and as this if my first season with FTC...frustrating.
Unread 20-10-2014, 23:44
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
Re: [FTC]: RobotC to legomindstorm NXT tetrix/matrix
You are using RobotC 4?
Make sure you have checked "External motor/servo controllers" item in the menu, this is all you need for Tetrix.
FTC 4137 "Islandbots"
islandbots.org
Unread 22-10-2014, 13:43
FRC #2906
I will look at that again. Can you take a screen shot of the offending selection and up load?
Unread 22-10-2014, 14:27
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
You have to open either the autonomous template or the Teleop template for the option to show up. It seems to be a wierd bug.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 22-10-2014, 19:16
FRC #2906
We are using robotc 4.26 for NXT. When we goto 'platforms' in 4.26, select lego mindstorms, then we get the choice of NXT and EV3. There is no tetrix at all. If we select the external motor control at the bottom of the list with lego mindstorms there is no additional platform options for the tetrix/matrix if we repeat the above steps. I have seen an older version 3.xx that has it. We would like 4.26 to work correctly. Any ideas or help are welcome.
WWWard
FRC 2906
FTC 5328
Unread 23-10-2014, 00:32
FRC #2906
Here is the link that I received from RobotC help. I will show it to the kids Saturday and see if we can make it work. There is no Tetrix/Matric platform as there was in Robot C 3.XX Once you turn on 'using motor/servo controllers' then goto File/new and select either the User Control or Autonomous templates. What I need seems to be there
Using Motor/Servo Controllers: http://help.robotc.net/WebHelpMindstorms/index.htm...
I hope that other can find this helpful.
WWWard
FRC 2906
FTC 5383
