Go to Post FIRST is our Hunger Games. May the odds be ever in your favor. - GeorgeM [more]
Unread 23-10-2014, 09:59
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: Question to the conveyor experts out there
Unread 23-10-2014, 10:02
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Question to the conveyor experts out there
I don't see how those could keep a chain from coming off if it loosened... the chain will move away from those shoulders, not towards them, so the shoulders can't do anything to stop the chain.
I would venture a guess that you're seeing either sprocket clutches designed to prevent overloading, or quick-change sprocket hubs designed to allow easy servicing and replacement of sprockets.
Edit: http://www.mcmaster.com/#drive-clutches/=u9ywqt
http://images1.mcmaster.com/Contents...ng?ver=4353711
Unread 23-10-2014, 12:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Chains running off indicate an alignment or frame stiffness issue. In an industrial environment you are generally better off fixing the underlying issues than treating the symptoms. So mostly what James said.
