Go to Post Only on CD would people debate calculus problems involving time and team numbers... - artdutra04 [more]
Unread 23-10-2014, 21:26
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
3 Axis CNC Milling Bevel Gears
I designed a bevel drive base gearbox a while back and the team has decided on making it. We have now acquired a CNC sponsor and we have no idea what tooling they have but they are not a hobbing shop. They should be able to handle all of the structural prices just fine but we want to CNC the bevel gears as well. Being that this would be the first thing we ask them to make I dont want to walk in there with an impossible part. How difficult would this be to machine? It does not have to be perfect when it comes out of the mill we would be willing to clean them up. I know a decent amount on CNC but not a bunch so I don't really know.
Unread 23-10-2014, 21:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 3 Axis CNC Milling Bevel Gears
That would take a 4th axis (or at least an indexer) and also a specialized involute profile gear cutter. Not sure how it would be programmed but it doesn't seem like it would be terribly complicated.
Unread 23-10-2014, 21:35
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
What kind of tooth profile?
What diameter?
What material?
What kind of bore/hub?
Unread 23-10-2014, 21:40
AdamHeard's Avatar
Lead Mentor
Not optimal by any means but they could be 3d contoured on a 3 axis.
Unread 23-10-2014, 21:44
Yeah I wasn't going to mention that but since you brought it up.... Need a really high spindle RPM, tiny ball endmil,, lots of program memory, and still not sure how you'll get it to cut on a true involute profile.
Unread 23-10-2014, 21:45
Dr.Gusta's Avatar
Team Role: CAD
Okay I had a feeling it would not work out well especially since they are so small. For custom gearing we could spend upwards of $500 including spares. Any ideas on other manufacturing techniques that may work. I was thinking of 3D printing a mold of the gear then casting it in plastic. Would that be too soft for a drive base?
Unread 23-10-2014, 21:49
AdamHeard's Avatar
Lead Mentor
Why do you need the gears to be custom?
Jared's Avatar
Jared Jared is offline
It'll be really difficult to cut the profile of a gear like this without specialized equipment. That said, you likely don't need a totally custom gear.
I don't think plastic has much of a chance of holding up in a drive application.
Is there a way to modify your design so that it uses bevel gears from McMaster?
If you're doing a large reduction with this gearset, you might consider using a worm gear instead.
Unread 23-10-2014, 21:51
headlight headlight is offline
headlight is an unknown quantity at this point
It is possible I'm sure.
The main thing that will be difficult depends on the size of the part, what kind of parts the shop normally does, and how deep you wanted the teeth.
Is it not possible to get an off the shelf bevel gear?
Unread 23-10-2014, 21:52
techhelpbb's Avatar
How about casting it in metal?
Unread 23-10-2014, 21:53
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
It all depends on the type of plastic and where it is in the gearbox. You should work on the gearing calculations if you want to do custom gearing to make sure that the widths of gear can handle the stress. That being said, the best way to go about this is to redesign the gearbox to use off the shelf bevel gears. This would be much easier for cost, replacement parts, and time.
Unread 23-10-2014, 21:57
Dr.Gusta's Avatar
Team Role: CAD
Thank you guys for all of the replies and the reason being for a custom gear is to try and keep the box as small as possible. I am going to toy around with the CAD and see if I cant get the small bevel gears to work from mcmaster.
Unread 23-10-2014, 22:00
Rafi Ahmed's Avatar
Mentor & Alumni
You should check out SDP-SI, they have a better selection for gears. http://www.sdp-si.com/eStore/CoverPg/Gears.htm
Unread 23-10-2014, 22:09
Fur custom gears you could try Rush gears. For off the shelf units you could try Boston Gear or WM Berg.
Rethinking my original plan to cut it, I don't think a traditional gear cutter tool would work, because of the tapered teeth.
Unread 23-10-2014, 22:39
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Cutting bevel gears isn't something that a typical "CNC sponsor" does often. Gear shops usually use more specialized equipment. In theory you might be able cut FRC sized gears with a small endmill, but that would probably not be the best use of a new sponsor. Real bevel gears have a variable tooth profile which are a more challenging. If it can't be redesigned to use COTS bevel gears (which is what I recommend), you can make fake bevel gears with a knee mill, an indexer, cutters like this http://www.ebay.com/itm/Lot-8pcs-Dp2...em2a3a82 b554 as detailed here http://homepage.ntlworld.com/corromant/bevel_gears.htm
Ryan Shoff
4143 Mars/Wars
CheapGears.com
