Go to Post I wonder if we sang songs to Bill Miller if that would get TIMS opened sooner, like the way it worked to wring game hints out of Dave Laverly. - rsisk [more]
Unread 23-10-2014, 23:12
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: 3 Axis CNC Milling Bevel Gears
Originally Posted by Dr.Gusta View Post
Thank you guys for all of the replies and the reason being for a custom gear is to try and keep the box as small as possible. I am going to toy around with the CAD and see if I cant get the small bevel gears to work from mcmaster.
I think this is a situation where the tradeoff between a easier to get, less optimal COTS part and a custom, higher performance part pretty definitively leans to one side.
-Plutarch
Unread 23-10-2014, 23:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by raf4far View Post
You should check out SDP-SI, they have a better selection for gears. http://www.sdp-si.com/eStore/CoverPg/Gears.htm
QTC is also in the same corporate family: http://www.qtcgears.com/RFQ/BevelGears.htm. You'll have better luck getting appropriately-sized bevel gears from them, than from most other suppliers. Call them to discuss, and to get a quote, and summarize the interaction here.
Unread 24-10-2014, 00:34
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Casting aluminum gears...
http://m.youtube.com/watch?v=7h7vA0ARJWs
Another option and quite possibly faster and safer, have Shapeways print the gears:
http://m.youtube.com/watch?v=B9VOwqtOglg
Unread 24-10-2014, 01:17
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I vote QTC. Rush Gears has a minimum order on the level of $1500 regardless of number. The gears from QTC are of pretty good quality even at the lowest quality they offer for metal gears, and you can buy ground gears if you need to. They have a very wide selection too.
It's very easy to modify the bevel gears if you sue a machinable collet to hold them; I have been shortening the hubs and widening the bores slightly for a project.
Unread 24-10-2014, 15:13
FRC #1836 (MilkenKnights)
Vex sells small and cheap 15T Bevel Gears
