Go to Post Most teachers are not in it for the income, But they are definitely in it for the outcome. - Bob Steele [more]
Unread 26-02-2003, 19:08
Chris Dibble Chris Dibble is offline
#0102 (Gearheads)
Chris Dibble is an unknown quantity at this point
Send a message via ICQ to Chris Dibble Send a message via AIM to Chris Dibble
Angry Major Inventor Problem
I've been using Inventor to design the robot, and am nearly finished. But recently, I've gotten an error which does not let me save! Here it is:
[WARNING] Problems encountered while saving the document. <FwRes.dll(1806)> [r:\core\Fw\Main\FWxSceneDoc.cpp, line 1431]
[ERROR] Error(s) detected while writing segment AmDcSegment in database C:\Documents and Settings\Dibble\My Documents\Chris\Activities\Robotics\Inventor\Robot \Robot Built Frame CTD2.iam <RSeRes(622)> [r:\core\RSe\segment\segStream.cpp, line 242]
[ERROR] Error detected while saving object of type RDxOccurrence <RSeRes(1408)> [r:\core\RSe\meta\meta.cpp, line 967]
[ERROR] Internal error in persistence operation (Segment loading is not supported within other persistence operations) <RSeRes(623)>
[ERROR] The database in C:\Documents and Settings\Dibble\My Documents\Chris\Activities\Robotics\Inventor\Robot \Robot Built Frame CTD2.iam could not be saved <RSeRes(202)> [r:\core\RSe\database\databaseC.cpp, line 1195]
Does anyone know why this is happening? I'm running on a 2ghz machine with 512mb ram, so it shouldn't be processor speed.
Please help if you can, I'll greatly appreciate it.
Thanks,
Chris
Unread 26-02-2003, 19:15
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
(shouldnt this be in the inventor forum?)
My best guess would be just to try uninstalling it and reinstalling it.
Purdue Alumni
Cummins, Inc.
Unread 26-02-2003, 19:47
#0102 (Gearheads)
It should be, and is, but I think it'll get more exposure here. And I did uninstall/reinstall (didnt' help).
Unread 26-02-2003, 20:52
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
If it should be in there, it shouldn't be in here. Extra cluter is not needed in the General Forum.
Jeff Waegelin
Unread 26-02-2003, 21:10
#0102 (Gearheads)
Fine, then remove it. I solved the problem anyways.
C
Unread 27-02-2003, 11:12
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
You can do that yourself....there's a section of the "edit thread" that says "Delete Thread" and you check it and hit ok....poof, gone
~Adam
