Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 24-10-2014, 13:44
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Driver's Station Joystick reset?
With using a new laptop for our drivers station we have the joysticks set up to not be easily rearranged. When ever the laptop is reset the 2 controllers get flipped around in the Dashboard and we have to go to joystick set up and flip them back. It happens every time the laptop is turned off. Is there a way to keep them in the same order? after the computer is shut off?
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 24-10-2014, 13:50
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Driver's Station Joystick reset?
I'm not sure if there is anything you can do in Windows.
The easiest fix I can think of would be just swapping joystick 1 and 2 in the code. That way the default order would be the correct order.
Unread 24-10-2014, 13:55
audietron's Avatar
Ok, Thanks I hadn't thought of that.
Unread 02-11-2014, 20:17
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Another thing might be to switch the ports that the joysticks are plugged in to on the computer.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 02-11-2014, 20:22
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is online now
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
As far as I remember, there is a text file that corresponds to the driver station settings (ip configuration, team number, etc.), and I believe that you can set any of the 4 joysticks to a certain name so that when that joystick is plugged in it will always associate itself with the number from the text file.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
