Go to Post An extra week of driving practice and shakedown outweighs a lot of ooo-shiny. - Billfred [more]
Unread 25-10-2014, 11:43
yash101 yash101 is offline
AKA: null
Re: Best way to learn C++
It ends up that I'm teaching many students C++. I am working on a repository of code examples to get everyone started. Everything's open source, so please feel free to use the code.
I haven't pushed yet, but I will today. The repository is at https://github.com/yash101/CodingClub
All the samples are written for Linux, and the binaries only work in Linux. However, you should have no problem compiling most of the code in Windows or Mac (where Mac will compile the code with the same command but will create a different executable).
Unread 25-10-2014, 13:26
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This won't teach you C++ for a robot, but it does have an open problem set in C++. It also takes a novel online approach to teaching - immediate community feedback. I used it & CodeAcademy to take a crash-course in javascript so I could figure out how to fix a complicated bug in someone else's code the night before a demo at work.
It's alot like ChiefDelphi - there are nuggets of wisdom, and best practices - but knowing which information to trust takes some experience.
http://exercism.io/
Unread 25-10-2014, 14:52
AKA: null
http://exercism.io/
Building on, I suggest that you begin by learning basic C++. Learn what a literal is. Learn what a function is. Learn what is a pointer is, etc. From there, move onto FRC C++. C++ is quite easy as long as you Pace yourself and don't try to build a rocket before you have built a bicycle!
I did push to my repository. I am still adding examples and hope to have a couple hundred soon! Good luck with C++!
