Best way to learn C++
Looking into programming our team's robot but I need to learn C++. Any suggestions as to the best method to learn it?
Re: Best way to learn C++
The college I go to outsources a lot of their classes (or maybe it's just the cs department, but still).
Here are the files: Lecture Slides Assignments |
Personally I started programming with Arduino, and it was a small step to C and C++ and Java from there, but you really should only go that route if you think you'll still have tme to learn how to program FRC-specific.
#7
It ends up that I'm teaching many students C++. I am working on a repository of code examples to get everyone started. Everything's open source, so please feel free to use the code.
I haven't pushed yet, but I will today. The repository is at https://github.com/yash101/CodingClub All the samples are written for Linux, and the binaries only work in Linux. However, you should have no problem compiling most of the code in Windows or Mac (where Mac will compile the code with the same command but will create a different executable). Last edited by yash101 : 25-10-2014 at 11:46. |
#8
This won't teach you C++ for a robot, but it does have an open problem set in C++. It also takes a novel online approach to teaching - immediate community feedback. I used it & CodeAcademy to take a crash-course in javascript so I could figure out how to fix a complicated bug in someone else's code the night before a demo at work.
It's alot like ChiefDelphi - there are nuggets of wisdom, and best practices - but knowing which information to trust takes some experience. http://exercism.io/ |
#9
I did push to my repository. I am still adding examples and hope to have a couple hundred soon! Good luck with C++! |
