Go to Post But FIRST isn't FRC anymore. We need to make way for FTC and FLL. - Tetraman [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 25-10-2014, 19:48
meg's Avatar
meg meg is offline
FRC #0900 (Zebracorns)
meg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to behold
Re: Student Time Logger
Originally Posted by Tanis View Post
That would definitely work. If you wanted to keep it simple, you could also make it a part of the application config along with the other settings that are currently available.
I definitely don't mean for you to turn this into a complete CMS type of system where you can customize every page to your liking, but those were just some of the things that I was considering tweaking myself for our team.
Of course, if you are fine with the added complexity some of this would add, I wouldn't complain
Features added. Instead of the tool use/code of conduct in the user, you can create "forms". Any thing from permission forms, to knowing how to use a specific form or entry fees if your team has them.
You can now set team name/number in the settings document as well as the name for the "school" field, if you'd like to change it to group, or team or whatever you'd like to call it.
Hopefully, it all works slightly better now!
