Go to Post If you look closer, you'll see I did those photos over a period of years... and they were only done with one program... but yeah, a little free time with no where to direct it and I can become, um, creative... - MissInformation [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 22-10-2014, 15:55
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Interesting idea I thought of today that I will develop, I am going to build an app that allows students to check themselves in and out using a PIN number, but can also scan barcodes. That way you can stand at the door and check other students in as well.
ORB Haow!
Unread 22-10-2014, 15:59
meg's Avatar
meg meg is offline
FRC #0900 (Zebracorns)
meg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to beholdmeg is a splendid one to behold
Re: Student Time Logger
I'm not really sure how that's much different than mine, other than that we don't give students admin access (to stop them from being able to sign in unless they're in the lab). It does use a pin number, it just happens that the pin number is the number used on the barcode. If you wanted students to simply enter a number, you could do that. If you want students to be able to log each other in, just give them admin access. Maybe I'm missing something?
Unread 23-10-2014, 21:48
itsjustmrb itsjustmrb is online now
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
We use mytimestation.com, they gave us a free account and can be used with an old iphone, iPad or android device. It also has a wide variety of reports to run or export to excel.
Mr B
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 24-10-2014, 10:11
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Thanks for providing this application!
I've been playing with a little bit for my team and I like it so far. I set it up on a heroku instance pretty quickly and painlessly.
For anyone else getting started and wondering how to set up your first users, just go to the registration page. The first user you create will be an administrator and everyone from then on will default to a standard user.
It would be nice to provide a little more flexibility- For example, it would be nice not to have to fork the project to change the team number on the welcome screen.
If we decide to go forward with using this, I will probably also rename the "school" grouping to simply be "group." We only have one school, and I think it would be interesting to separate students by their subteam (build, programming, etc.). Not something I would expect you to change because this is obviously what works for your team, but just something that was on my mind.
Similarly, I would imaging that a lot of teams would want to customize the registration process to either add or remove certain fields (such as the "tool use forms" checkbox).
Team 2052- KnightKrawler
Mentor and volunteer
Unread 24-10-2014, 11:56
meg's Avatar
meg meg is offline
Were you thinking database variables? I could probably do something like that.
I have no objection to changing the names. Group could be a school as easily as a specific team. I'll see how easy it will be to modify since we've already got a database with values.
That's a FANTASTIC idea! Custom checkboxes. New database tables, definitely doable though. I'll see what I can do. Maybe not in the registration itself, but instead as an associated object?
I'm glad you're liking it so far, if you have any more suggestions please don't hesitate to let me know!
Unread 24-10-2014, 13:05
AKA: Bryan
That would definitely work. If you wanted to keep it simple, you could also make it a part of the application config along with the other settings that are currently available.
I definitely don't mean for you to turn this into a complete CMS type of system where you can customize every page to your liking, but those were just some of the things that I was considering tweaking myself for our team.
Of course, if you are fine with the added complexity some of this would add, I wouldn't complain
Unread 24-10-2014, 13:27
meg's Avatar
meg meg is offline
Compared to some of the scripts I write, that's not complex at all! I thought I had put the team name in the config file, I must have forgotten that reference to it. Should be easy enough to do once I get home.
As for the Tool Use option, I was just trying to find a good way to track permission slips for our team, so I figured why not! Group Vs. School is just a matter of finding the name and replacing it, ultimately it doesn't change the main body of the code.
Unread 25-10-2014, 19:48
meg's Avatar
meg meg is offline
Features added. Instead of the tool use/code of conduct in the user, you can create "forms". Any thing from permission forms, to knowing how to use a specific form or entry fees if your team has them.
You can now set team name/number in the settings document as well as the name for the "school" field, if you'd like to change it to group, or team or whatever you'd like to call it.
Hopefully, it all works slightly better now!
Unread 25-10-2014, 21:28
AKA: Bryan
Looks even more awesome! Thanks!
Unread 25-10-2014, 22:09
meg's Avatar
meg meg is offline
Happy to do it. Let me know if you have any more suggestions or requests
Unread 25-10-2014, 23:02
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Adam, I'm not really sure I understand your post. I was showing my team's solution to the problem and offering it up to other teams should they choose to use it.
I guess that I was also doing the same. I was saying that I also have one out there and that there are many ways to do the same thing. I tried yours out and I would just like to basically add in there what one benefit of the one that I created is that the reason that we created it is because we wanted to track not only the total hours, but how many hours we spend on each aspect of the robot all the way down to the different components. I do like yours for ease of use as the TM only needs to input the ID number or even scan the barcode for that matter!
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
homepage: newulmrobotics.com
