Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Go Back   Chief Delphi > Technical > IT / Communications
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 25-07-2013, 15:15
Joining the 900 Meme Team
FRC #0079
Re: Team 254 Open-Source Release: Cheesy Parts
Originally Posted by Jon Jack View Post
If you were interested in just checking in and out files, then yes you could use Git. However, Git is intended to be used with text files, not binary files like the ones created by SolidWorks.
In SolidWorks different files are associated with each other. For example, an Assembly will have many parts associated with it. Git has no way of recognizing these types of relationships. So if I'm using Git and I wanted to check out an assembly and all the parts associated with it, then I'd have to manually check out each part. If I wanted to do this in PDM then all I'd have to do is check out the assembly and check a box that checks out all associated files.
There is a tool called git-annex that is meant to work with large binary files. I haven't personally set up a repository but I have had the experience of using it for a project at work. We were using it to track multiple terabytes of video data and it worked well.
  #32   Spotlight this post!
Unread 25-07-2013, 15:30
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
jacob9706 is on a distinguished road
Looks handy!
One sugestion I have is add the ability to upload a photo for each part. This would be great if students did not know a part by name and were able to see a cad drawing or a picture from a previous season related to the part when they clicked on a part!
Simple to implement but will drasticly improve the look and feel of the "part description" page!
* Team 3574 Alumni
* 2011 - Highest Seeded Rookie
* 2011 - Rookie All-Star
* 2012 - Engineering Inspiration
* 2012 - Olympic Deans List Winner
* 2013 - Engineering Inspiration
* 2013 - Judges Award (For unique circular robot and the way the team works together.)
  #33   Spotlight this post!
Unread 26-07-2013, 01:25
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Originally Posted by Zach O View Post
Just got it running. Thanks Pat - this looks awesome.
Quick support question: When I try restarting/stopping/starting (after the first time) it using the parts_server_control script, I get an error
https://gist.github.com/ZachOrr/6081673
Suggestions?
Zach, I can't reproduce this -- maybe it's something to do with the way RVM handles gems? I just realized I'm not requiring "bundler/setup" at the top of the control script like I should be, so maybe just running it as "bundle exec ruby parts_server_control.rb" will do the trick.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
  #34   Spotlight this post!
Unread 26-07-2013, 11:10
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
Weird - running "bundle exec ruby parts_server_control.rb restart" told me it couldn't find the gems it needed, and prompted me to "bundle install", in which it reinstalled all the gems and will restart/start/stop properly now (with or without the bundle exec in front of the ruby command).
I wonder how I got it running in the first place. Anyways. Thank Pat!
Follow me twitter dot com slash frc zach
  #35   Spotlight this post!
Unread 26-07-2013, 14:58
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Is rubygems.org down a lot? For some reason, it looks like I can't connect to it, and I can't ping it, although the rubygems.org site works just fine.
-Plutarch
  #36   Spotlight this post!
Unread 13-08-2013, 16:17
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
254
Thanks for posting this. Its obvious that a lot of effort went into the development of this system. I've just finally gotten around to playing around with the working demo and am very impressed. While tinkering I came up with a few questions:
  • How do you integrate this with your purchasing group to procure all the raw materials and parts? It looks like some of the parts just have descriptions while some add a part number and/or manufacturer name. How does the person purchasing know what to order and where from?
  • Who is in charge of setting up new parts, choosing when to group things into a subassembly, what to name something, etc?
  • Who keeps this updated throughout the season? Is it one single person, a group? Is it updated hourly, daily, weekly?
  • Did this system solve the issues you were attempting to address?
My team tends to run pretty lean, and often the same mentors aren't there on consecutive nights. When that happens things slow down as we try to figure out what needs to happen next. A system like this could really help us keep things more focused from night to night. I'm curious to learn more about how you used it and how well it worked.
  #37   Spotlight this post!
Unread 14-08-2013, 01:29
Circuit Breaker
Originally Posted by craigboez View Post
254
Craig,
We didn't have purchasing integration for 2013, but we're working on it for 2014. We kept track of parts needing to be ordered in a Google spreadsheet, and someone would periodically check Cheesy Parts and make sure everything that was in "needs to be ordered" status was added to the spreadsheet. Obviously, this was a bit painful.
The designers each make the naming/grouping decisions for the parts that they are working on. The addition of the parts to the system is done sometime between when a file is created and when it is first saved to PDM. You can't really save something without knowing what to call it, and so since Cheesy Parts assigns the part numbers this pretty much enforces itself.
Everyone on the team has access to the system, so the responsibility for keeping it updated is shared. Generally, whoever worked on the part last is responsible for updating its status accordingly. This wasn't totally successful, but the worst offenders were some of the mentors...
I can't speak for the rest of the team, but in the project manager / shop supervisor role that I mostly find myself in during build season, it was a huge help when confronted with a bunch of students to find tasks for, and in keeping the stress levels down.
Patrick Fairbank
patfairbank.com
  #38   Spotlight this post!
Unread 14-08-2013, 20:11
AdamHeard's Avatar
Lead Mentor
For someone who has no idea what they're doing with websites, someone mind posting instructions on how to install this? As if I were five please.
  #39   Spotlight this post!
Unread 14-08-2013, 20:57
DampRobot's Avatar
Physics Major
AKA: Roger Romani
For just installing, see one of my previous posts on this thread. I have pretty much zero programming experience, so hopefully my instructions make sense for you.
Just FYI, I've had trouble reinstalling it after Pat updated the software, and haven't gotten it working since.
-Plutarch
  #40   Spotlight this post!
Unread 26-04-2014, 03:13
nicolelin nicolelin is offline
Gracious Profishionalism
FRC #0649 (M-SET Fish)
Team Role: Scout
nicolelin is an unknown quantity at this point
Just curious - has anyone tried setting this up locally yet?
Yeah, my team is going to try to integrate this system into our management of parts. We've got it running on Linux (Ubuntu). It's much easier to install MySQL and actually start playing around with it
This is a super great idea, and thanks to the Poofs for releasing this open-source.
  #41   Spotlight this post!
Unread 20-10-2014, 09:42
schlegels schlegels is offline
FRC #3003
schlegels is an unknown quantity at this point
I'm in the same boat as you. I am hesitate to try and follow DampRobot's instructions unless I can get confirmation that he has been able to get it working again. Our kids would really like to get this up and running for the team but I'm not sure how to get it installed.
  #42   Spotlight this post!
Unread 20-10-2014, 10:44
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Yeah, PDM integration is something I'd like to add if possible. One issue we have is Cheesy Parts getting out of sync with the CAD because some people are too lazy to create entries in it before saving their parts to PDM (cough EJ cough), so being able to query PDM and automagically create Cheesy Parts entries in that case would be nice. It's not going to be a walk in the cake, though, since the only way I've heard of to integrate with PDM is through some .NET DLL.
We're using a t1.micro EC2 instance running Ubuntu 12.04. It would probably be fairly trivial to deploy Cheesy Parts instead as a Heroku or AppFog app, though -- I just like the extra control that a virtual private server provides.
Thank you for posting this!
We're going to deploy this on Heroku and try to set it up. Our lead CAD mentor might be in touch with you guys for running PDM. We had a lot of issues with it last year and have abandoned it for now (Using Google Drive instead).
Also, for what it is worth, https://www.digitalocean.com is cheaper than Amazon for micro instance sized stuff and provides roughly the same amount of control. We run our primary site off of digital ocean. It's really because I'm a Linux Container nerd though and not so much about the price.
Also, it just so happens our other main mentor is a Ruby wizard so she is taking on setting this up on Heroku.
Again, thank you for posting this.
  #43   Spotlight this post!
Unread 26-10-2014, 17:08
Jared's Avatar
Jared Jared is offline
I'm having a hard time installing this. I've done it in the past on ubuntu, and everything worked the first time perfectly, but now I'm installing it on new machine, which doesn't have all the dependencies I usually work with.
When I run "bundle exec rake db:migrate", it fails, with the error "cannot load such file -- db". I've tried with ruby 1.9.1 and 1.9.3, and the same error happens. What am I missing?
  #44   Spotlight this post!
Unread 26-10-2014, 18:32
Jared's Avatar
Things are messed up with relative paths in the requires for some reason.
I solved it by removing line 16 in the Rakefile (require "db"), and replacing
Sequel::Migrator.run(DB, "db/migrations")
with
 Sequel::Migrator.run(Sequel.mysql2({ :host => "**host**", :user => "**mysql user**", :password => "**mysql  password**", :database => "**mysql database**" }), "db/migrations")
Replace the things surrounded by *'s with the actual values.
There was also an issue with require in the add starting user file. I needed to add a ./ before the path name.
Finally, the version of sequel (the ruby gem) that installed automatically was totally the wrong version and needed to be updated.
