Go to Post You lame pig farmer! I'm not talking about a bunch of dudes sitting around eating their packed lunches that Mommy made. - Paul Copioli [more]
Unread 27-10-2014, 11:01
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Greasing "open" gearboxes
So my team and I are working on a drive gearbox and it has pocketed face plates much like the WCP style (image below). What we were wondering is how to keep grease from flying off of the gears. We use white lithium and when the gears get to speed they will throw all of the grease off. This could be solved by not doing pockets all the way through (leaving a 1/16in) when milling the plates but I was wondering what other teams did to solve this issue that had WCP type gearboxes.
http://imgur.com/NAilpGr
Unread 27-10-2014, 11:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Greasing "open" gearboxes
try a dry graphite lubricant?
Unread 27-10-2014, 11:34
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Most of the grease is going to come out of the sides of the gearbox; in the last few years I can't remember any grease coming out of the front or back. You can put something around the gearbox to keep debris out and grease in, or you can run grease through the gearbox for a while until it isn't spraying grease anywhere and then install it into the robot.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 27-10-2014, 11:38
Aren Siekmeier's Avatar
on walkabout
If a significant amount of grease is being thrown from your gearbox, you don't need it. You have too much grease. You only need to apply a fingertips-worth to a spot on each gear, and then spin the gears a bit to spread it evenly.
Unread 27-10-2014, 11:44
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
we cover ours with duct tape - this does two things - it keeps the grease in, and it keeps the dirt and other damaging materials out.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 27-10-2014, 11:45
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We did this with the KOP gearboxes lady year-round greased them then let them run for a couple of minutes before installing them on the robot. We ended up taping over the ends anyways to keep debris out as well.
2016: Lake Superior WFFA
Unread 27-10-2014, 12:42
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
We used this last year:
http://www.mcmaster.com/#8710t44/=uc2zsu
Had to reapply a couple of times, but it dried on and didn't 'fling' off the gears. We applied it a few times through the year, but it worked well.
