Go to Post Note to self for next year, apply physics rather than "well, this SEEMS like it would work." - Karibou [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 27-10-2014, 14:58
Volunteer, WPILib Contributor
no team (Waiting for 2021)
2015 Compressor Fuse
It was brought to my attention this week that there might be a fairly major issue with the way the Pneumatics board is powered, and the Compressor. The PD board uses 1 20a mini fuse to power both the Voltage Regulator board and the Pneumatics board. The Voltage board is what is powering the Radio, and there is functionality in the Pneumatics board to power the compressor. Running both of these off of 1 20a fuse could be a major issue, because I remember popping 20a fuses in spikes before we replaced them with the breakers. With the way the system is setup now, if the compressor pops the fuse, it will shut off the radio. Have any of the beta teams talked about this to make sure this doesn't actually become an issue?
Team 4488 - Mentor 2013-2016
Unread 27-10-2014, 15:13
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: 2015 Compressor Fuse
Significant testing has been done with the PCM and the compressor, and I haven't heard of a single fuse blowing. The PCM is capable of starting the compressor without surging power across the fuse, which was the cause odd burned out spike fuses.
2016: Lake Superior WFFA
Unread 27-10-2014, 15:29
Correction: one Beta Test team did report blowing the 20A fuse. It happened after they intentionally overstressed the VRM's 12 volt 2 amp output (which apparently resulted in the VRM itself failing as well).
Unread 27-10-2014, 15:32
Jared's Avatar
Jared Jared is offline
I pointed this out in the beta hardware thread.
Personally, I don't like this setup, where the radio fuse is non resetting and is shared with a compressor and other items, but I believe the compressor fuse won't blow very easily because it now has a current limited start.
Unread 27-10-2014, 16:09
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
We have been running a compressor on the PCM since the Alpha test days and have never blown the 20amp fuse.
We have blown the internal (soldered) fuses inside of the PCM and VRM, but that was due to our own destructive testing.
When wired correctly, the PCM and VRM should never blow the 20a fuse.
The VRM has multiple internal fuses, and if there is a short on one of its lines, the fuse internal to the VRM should blow before the 20A fuse is affected.
However, I said wired correctly, if the PCM wires short, or the VRM wires short at the PDP, then yes, you will blow the fuse, the wires won't short as long as proper wire gage is used, we have been using 18 awg security wire, which has a nice small jacket that slides into the wieldmuler connector. If you used 18 awg speaker wire, the larger jacket may not fit, and some of the wiring will be exposed.
The PCM has a feedback loop running and monitoring the current output of the compressor, the controller can sense and react to current changes way faster than the fuse can, which is why the fuse should not blow.
To help ease everyone's mind, we have actually replaced our 20A fuse with a 15A fuse on the PDP to see if that will blow, and so far we have not blown the 15 amp when running the radio on the VRM and 3 solenoids and a VAIR 92 on the PCM.
Correct wiring and attention to your setup, should yield a perfectly functioning system.
Now, the only other potential I see if teams trying to power other 5V devices from the same VRM that is powering their radio. I would say "Don't even think about doing that". Have one regulator for the D-link, and another for all other 5v items (camera, off-board processor etc.). The VRM can only output 2.5A MAX on the entire 5v Rail, and 2.5A MAX on the entire 12V rail. The D-link wants 2A just for itself based on manufacture spec.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 27-10-2014, 16:23
The VRM is only rated for 2a max peak momentary.
It's 1.5a continuous.
Unread 27-10-2014, 16:59
Controls Engineer
AKA: Kevin
Is this information provided by CTRE, or empirically measured by your team? If this is true, which goes against my current understanding of the VRM, how does the 1.5a continuous split across the 500ma Max Channels, and the 2A max channels on the VRM rails?
Based on my discussions with Mike from CTRE, I was under the impression that each rail supplied (12V and 5V) on the VRM has a max of 2.5A, and that the channels for each rail were limited to 2A, and 500mA, but these were all continuous sources, not momentary.
Regards,
Kevin
Unread 27-10-2014, 17:30
Both.
See Copioli's Beta comments:
#21
#18 (the last statement)
Unread 22-01-2015, 21:36
Dervish77 Dervish77 is offline
FRC #0467 (Shrewsbury Colonials)
Dervish77 is an unknown quantity at this point
So if you happen to blow one of the 20A fuses on the PDP, where do you find new ones? Neither AndyMark or VexRobotics appears to carry them.
Someone said that these are the same as automotive mini-fuses. Is that true?
Thanks,
- Brian
Unread 22-01-2015, 21:38
I got ours at Pep Boys.
Unread 22-01-2015, 23:23
Thanks,
- Brian
See page 12 of the user guide: http://www.crosstheroadelectronics.com/PDP%20User's%20Guide.pdf
Both automotive fuses are type ATM automotive blade mini fuses. Spares can be purchased at most hardware stores (Do not purchase ATC as they will not fit).
Unread 22-01-2015, 23:27
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
If for any reason someone cannot find these fuses in your area, our FTC team bought a bunch and have more than enough to last the next 20 years of FTC. I think they can spare a few.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Thanks,
- Brian
Yes they are automotive "mini" fuses available at any auto parts store or Walmart and under the dash and/or hood of many modern cars. Many brands like Fords actually have spares in the cover. I suggest picking up a pack of both the 20a and 10a to have on hand just in case, cheap insurance.
Unread 23-01-2015, 23:20
Thanks for the tips everyone!
I have now also found them on Amazon here
http://www.amazon.com/Bussmann-VP-AT...gy_auto_text_z
and here
Thanks,
- Brian
Unread 24-01-2015, 01:10
Mr V's Avatar
FRC #5588 (Reign)
and here
Thanks,
- Brian
A 25 pack seems excessive, the 5 pack at the local store will be more than enough to have on hand to prevent the installed ones from blowing.
