Go to Post Know what really grinds my gears? Metal Shavings. - Briansmithtown [more]
Unread 27-10-2014, 18:52
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Is this Equation Correct
Originally Posted by Jared View Post
Likely not.
If nothing on my robot is moving, then rps = 0, and my robot can hold no weight, according to that equation.
The weight which a robot can hold depends on the strength of what supports the weight.
Why do the number of wheels, strength of drive, or speed at which the robot is travelling have anything to do with how much weight can be held?
What units are you using for torque? For wheel radius?
Number of wheels would determine how weight is distributed to the ground. Actually, that would only be number of wheels in contact with the ground. Four 3/8 axles can support far more than one.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
