Go to Post We must remember: if you're reading this comment right now you already "get it." - akeisic [more]
Unread 27-10-2014, 15:27
Mad Cows Mad Cows is offline
FRC #3413
Mad Cows is an unknown quantity at this point
Is this Equation Correct
So I have been trying to work out an equation for the maximum weight a robot can hold. Does this look right?
https://drive.google.com/file/d/0B8z...ew?usp=sharing
T is torque of one motor, Mn is number of motors on one side, Wn is number of wheels on one side, Wr is wheel radius, Fs is static friction, rps is revolutions per second, m is mass.
The robot is a tank drive, with chains linking all wheels on each side to the motors.
Unread 27-10-2014, 15:48
Jared's Avatar
Jared Jared is offline
Re: Is this Equation Correct
Likely not.
If nothing on my robot is moving, then rps = 0, and my robot can hold no weight, according to that equation.
The weight which a robot can hold depends on the strength of what supports the weight.
Why do the number of wheels, strength of drive, or speed at which the robot is travelling have anything to do with how much weight can be held?
What units are you using for torque? For wheel radius?
Unread 27-10-2014, 15:51
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Your units do not work, which should is an easy sign that something is wrong. You have torque*distance/force/time = distance^2/time on the left side, and mass^2 on the right side.
Additionally, I'm having trouble understanding what you are trying to solve for in this equation. Is it the maximum mass that the robot can have before the wheels can't spin because they stall?
Unread 27-10-2014, 15:57
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
A quick search (admittedly, by searching Ether's posts) found me this white-paper, which might be useful:
http://www.chiefdelphi.com/forums/sh...d.php?t=119442
While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic.
Unread 27-10-2014, 18:52
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Originally Posted by Jared View Post
Likely not.
Number of wheels would determine how weight is distributed to the ground. Actually, that would only be number of wheels in contact with the ground. Four 3/8 axles can support far more than one.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 28-10-2014, 12:34
FRC #3413
Ok. So here is my new equation:
https://docs.google.com/file/d/0B8zt...p=docslist_api
Problem is, this equation does not factor in speed needed. How would I add that to the equation?
Unread 28-10-2014, 12:39
Nate Laverdure's Avatar
FRC #2363
It looks like you are trying to solve a dynamics problem. Have you first completed steps 1 and 2 (PDF link)?
Would you please answer the questions posed by the previous posters?
Unread 28-10-2014, 13:29
Your units still do not check out unless you happen to be using a unit system which makes some terms unneeded (e.g. a unit system where the acceleration due to gravity g is 1). Additionally, I still can't help you if I don't know what you are trying to solve for in this equation.
Unread 28-10-2014, 15:09
FRC #3413
Ok. So we fixed the equation, just remove the RPS. Our we are solving for W (Which is maximum stalling weight in newtons).
The last thing needed is how to add in a minimum top speed.
Radius is in meters, torque is Nm, everything is metric.
Unread 28-10-2014, 15:29
The quality of the help you get will be proportional to the effort you expend to clearly explain what you are trying to accomplish.
"maximum stalling weight" as a function of "minimum top speed" is not a completely unambiguous description. Here's a case where more words would probably be better than fewer.
