Go to Post Pit Tools Distraction=bad - Lil' Lavery [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 14-09-2014, 14:28
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Best gyro for frc.
I have been looking into different gyros online for an offseason project and am not sure which one to go with. The applications will be at least as demanding as FRC if not a good bit more. This means we would like minimal drift and for it to remain accurate under high acceleration.
Anyways could any teams who use gyros in their robot tell me which gyro they used and if they recommend it. (Shoutout to 1717 and 16, you all probably have good gyros for your swerve, it would be greatly appreciated info)
Unread 14-09-2014, 19:15
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Best gyro for frc.
1538 had very good results with Analog Devices gyros.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 14-09-2014, 21:53
RyanCahoon's Avatar
RyanCahoon RyanCahoon is online now
FRC #0766 (M-A Bears)
I used a ADXRS453 for the NASA Sample Return Challenge this year and was impressed with the performance for the cost.
FRC 766, 2015-, Mentor
Unread 15-09-2014, 10:06
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
I had a opportunity to test several different gyros (from two different manufacturers) on an FRC robot for a personal project and like the others, I would recommend the Analog Devices gyros. The one I am currently using is the ADXRS450 (similar to the ADXRS453 above - except without the internal temperature compensation) and it works well. If price isn't an issue, higher quality gyros are available with some excellent specs, however they typically run more than $1000.
Mike
Unread 15-09-2014, 12:00
We've been using that gyro as well, and it works incredibly well. Very low drift, very low acceleration -> yaw coupling.
Unread 15-09-2014, 12:21
AdamHeard's Avatar
Lead Mentor
2 years in on the same gyro for us, I wish we had used it with our swerve in 2012!
Unread 15-09-2014, 13:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Is there a place to get an pre-made IMU for this gyro? Quick googling doesn't seem to bring up anything state side.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 15-09-2014, 15:23
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
The part # for the evaluation board is : EVAL-ADXRS453Z
Mouser and digikey sell these.
Never actually used this but I had it bookmarked to buy eventually.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 15-09-2014, 15:47
Jduffy Jduffy is offline
FRC #2451
Jduffy is an unknown quantity at this point
We tried to use an MPU6050 breakout and arduino last year, but combining everything fairly difficult, so we just bought a nav6 from kauai http://www.kauailabs.com/store/index...&product_id=50
They're $70, but designed to work with a cRio out of the box, and will probably work with an rRio with a serial cable. It worked over usb to my computer, and the new rio runs linux, so it should be fairly easy to set up.
We used it to make our swerve field-centric, and it only floats by a degree or two throughout the match, which is about as good as you'll get with a cheap chip gyro.
If you want to make your own, arduino and an MPU6050 is a good place to start, there are several good libraries and explanations to get you up and running fairly quickly.
Unread 15-09-2014, 16:45
At some point, I'm going to make a board for it for the roboRIO. Given my schedule, don't hold your breath for it... It will most likely be available through WCP.
Unread 15-09-2014, 18:22
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
If you want to use the arduino and the MPU6050 and assemble something yourself, I highly recommend you ensure that the interrupt pin from the MPU-6050 is connected to the Arduino. This will allow interrupt-driven operations which is the way to get good performance. If you go to the nav6 website (https://code.google.com/nav6) you'll see schematics that show how to hook it up. All the nav6 open source code is available there too - and it's Arduino-compatible w/an Arduino UNO.
Do keep in mind that the MPU-6050 is a 3.3V part, and isn't 5V tolerant, so you'll need to take care of that. The nav6 does that, and also allows powering directly off the 12V robot battery.
One of the nice things about using the nav6 firmware, even if you assemble it yourself, is it will work w/all the WPI classes (java, C++) as well as w/the LabView VIs (these are also on the nav6 website). A few people who have the RoboRio beta systems are testing out the nav6 on the RoboRio, and although I haven't got word yet how well it's working for them we expect it should work just fine.
If you have any questions, please contact me at scott@kauailabs.com.
Unread 28-10-2014, 16:03
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
Hey Adam,
I noticed that the pin out on these gyros are different from the KOP sensor board. How would you interface these with the control system we have with FIRST. I know you have to set up a SPI connection with SCLK, CS, MOSI, MISO, I just have no background with this.
EDIT: Found it. For anyone who wishes to know how to wire the ADXRS453. It is just like the accelerometer. You will take the SCLK, CS, MOSI, MISO to the DIO pins 1-4, doesn't matter really what order, and can power it from the 5V or Ground located below the DIO pin 1 location. Thanks all and hope this helps someone else out.
"There is no luck. It is only when preparation meets opportunity."
Unread 28-10-2014, 17:05
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
I assume you use the SPIDevice class in Java (for example)? If so, can someone with experience using the ADXRS453Z provide feedback on the correct bit order, clock polarity, clock rate, and frame modes?
Any sample code you code provide would be helpful, which could help avoid hours of troubleshooting.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 28-10-2014, 18:46
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
This guy if you don't want to use SPI:
EVAL-ADXRS642Z - about $75 from mouser, digikey, etc
http://www.analog.com/en/mems-sensor...s/product.html
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 28-10-2014, 18:47
AdamHeard's Avatar
Lead Mentor
Austin Schuh is really the best to answer those questions here.
Colin Wilson (254>973>254) made ours, and could also answer but he's less active on here.
