Go to Post Robots that don't obey the laws of physics will be checked for alien technology and magic. - Greg McKaskle [more]
Unread 27-10-2014, 20:13
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
Andymark/Vex Dog Gears Interchangeable?
I'm not sure if this has been discussed or not, but are AndyMark and Vex Dog/Dog Gear's interchangeable? I want to use a standard AndyMark dog shifter assembly but instead of an AndyMark 48t I want to switch it with a Vex 50t. Looking at the drawings they seem like they'd work, or would take little modification to make work, but I just want to be sure.
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
Unread 27-10-2014, 20:29
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Re: Andymark/Vex Dog Gears Interchangeable?
I have switched these out with success. Though I swapped a 45 tooth for a 45 tooth gear.
There is no reason I could think of that it wouldn't work.
Unread 27-10-2014, 20:37
Jared's Avatar
Jared Jared is offline
It depends on the gears. The Vex Pro dog has a bigger OD than the andymark one, so on a small gear, like the 28 tooth AM gear, the Vex Pro dog might be too big.
Also, some andymark gears have a 0.875" bearing bore as opposed to 1.125". The vex pro bearing bores also cause the bearing to stick out the back of the gear more than the andymark ones do, so you may need to increase the depth of the bearing pocket.
Unread 28-10-2014, 13:05
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
To make sure that spur gears mesh you nominally need to match the diametral pitch (DP) and pressure angle are the same. To replace gears 1-for-1 the tooth count must also match. I assume this is what you're really interested in. Most of the common AM & VexPro gears are 20DP and 14.5deg pressure angle, so the teeth should mesh just fine.
Dog gears are something else entirely, they are the mechanism that 'shifts' in your normal AM shifter transmission. A VexPro shifter transmission uses a 'ball shifter' mechanism that functions in a slightly different manor from a dog gear.
Dog gear.
Spur gear with dog gear on the side.
Spur gear.
Unread 28-10-2014, 22:19
AKA: Rich Jr.
Sorry I should of clarified my terminology, my team typically calls the spur gears with the dog cut outs dog gears and the part that attaches to the shaft and engages the gears the dog.
So to restate my post, to achieve the spread I'm looking for, I want to use a VexPro spur gear(50t with the dog cut outs) with the AndyMark Dog. So has anyone had issues or needed to make modifications to use an AndyMark Dog with a VexPro spur gear?
2001 NY (Imagery)
Unread 28-10-2014, 22:25
AdamHeard's Avatar
Lead Mentor
Open them both up in CAD, and see if they physically will fit together based on the angular width of the teeth.
I've never verified personally, but I would assume they will fit. Please do the above and verify for yourself though.
Unread 28-10-2014, 22:51
AKA: Rich Jr.
Wow, I feel like an idiot. I have no idea why I didn't think of this, woops. Sorry guys for the useless post, it seems like it should work just fine.
2001 NY (Imagery)
Unread 28-10-2014, 23:15
AdamHeard's Avatar
Lead Mentor
No worries.We all start somewhere.
You asking answered the question for others afraid to ask.
