Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Unread 29-10-2014, 00:20
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
pic: Concept 6W Drive Train
Unread 29-10-2014, 00:21
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: pic: Concept 6W Drive Train
Any particular reason for cutting off the corners? Does it help much in giving more area for a given perimeter?
Definitely have to concur that simple is good.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 29-10-2014, 00:23
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Looks solid.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 29-10-2014, 00:51
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looks a little too solid IMO. There's a ton of 1x1 on there.
However, 34 lbs is still pretty light for six cims (actually that's very light) so adding in a shifting gearbox would make good use of that drivetrain I think. It's only a couple pounds more, and allows for safe top speeds of 18fps+ without worrying about main breaker trips.
Unread 29-10-2014, 01:00
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
What makes this drive train better than a kitbot with nitrile treads and 6 cim gearboxes? If you want to keep it simple why not go that route?
2016: FRC 865 Mentor
Unread 29-10-2014, 01:04
Andrew Lawrence
Posts: n/a
How is that any simpler than this?
Unread 29-10-2014, 01:13
AdamHeard's Avatar
Lead Mentor
It's not.
Unread 29-10-2014, 01:21
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Oh I just noticed:
Your main gearbox shaft is attached to the out frame member. If the outer frame becomes damaged in a collision and bends a little, it will damage the efficiency of the gearbox, and possibly render you immobile on one side.
Also, what's the reasoning behind cutting the corners? It seems like extra work to me.
Unread 29-10-2014, 01:34
EricH EricH is online now
It's not.
They are trying to work within their existing resources, and this is a simple design that fits within those resources. I would probably find it reasonable to assume that they don't anticipate having the funding to buy Versa, or to buy Versa and still do X, Y, and Z that they want to or need to do. Or that they're one of the teams that prefers making over buying (there are a few out there).
Is a WCD simpler? Maybe. But if you're doing all the machining for it, there are some advantages to NOT doing a WCD (like having more time!). Even if you are thinking of buying one, there could still be advantages to not doing one (dead-axle setups tend to be a trifle easier than live-axle setups in terms of manufacturing, something about no keyway or hex).
Unread 29-10-2014, 01:42
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Are the gussets at the corners supposed to be seperate strips or angle iron? If they are seperate strips, it looks like a hard hit to the upper member could severely bend it inwards.
Edit: The upper 1x1 above the wheels
(2015-?): 973
(2012-2015): 955
Unread 29-10-2014, 01:44
Andrew Lawrence
Posts: n/a
A full versachassis can get expensive, I'll admit that, but just using some of the parts can greatly simplify this design and make it not only more effective, but more reliable as well. You don't need to buy an entire drivetrain setup, but using what your resources will allow can greatly simplify things.
You don't need to break bank on COTS parts to make a great drivetrain, but ignoring the cost effective resources available to teams isn't the answer either.
Unread 29-10-2014, 02:02
T-Dawg's Avatar
T-Dawg T-Dawg is offline
Team Manager
AKA: Alan
FRC #0955 (CV Robotics)
T-Dawg is an unknown quantity at this point
Is there a particular reason why the corners of the chassis are cut off?
The only reason I can think of is if you're trying to make the chassis fit within the 112 inch frame perimeter.
Otherwise, I don't see a structural benefit of cutting the corners off.
Unread 29-10-2014, 02:14
Spoam's Avatar
Spoam Spoam is offline
AKA: Pedro M.
Spoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the rough
Otherwise, I don't see a structural benefit to cutting the corners off.
If I had to guess it would be that they're trying to keep all the 1x1s the same length for convenience? Then cut ends to keep it flush. Personally though if that's it then I might rather have the extra support from corners.
Unread 29-10-2014, 06:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
(nvm)
Unread 29-10-2014, 12:45
Deke's Avatar
no team (No Team)
It gave about 4.5" inches in perimeter back, so the frame is at 28 x 30 with ~ .5" to spare. The small increase in bumper complexity seems worth the extra 4.5".
I think you are right depending on the game, but I would like to avoid the added complexity and cost if possible. Most games don't require 18 fps imo.
Not much, it helps with bumper support and added area for mechanisms. I also like how the gear box gets packaged. We like to build as much as we can in house. The kitbot wouldn't have the students machining the components.
You are correct with how we are thinking. I would argue once you add bumper support and interfaces for mechanisms to a WCD, it is more complex. This structure immediately supports the bumpers and provides a little better locations for mechanisms imo. We also try to build as much as we can in house. We are fortunate enough to use the manual lathes and manual mills in the school to build.
Oh I just noticed:
With the bumper outside of the frames protecting them, I am not to worried about it. The dead axles also act as cross members supporting the outside lower beam. If the upper beam needs more support, cross members could be easily added. The corners being removed reduces the frame perimeter, allowing more length or width to be added.
Using angle pieces to connect the beams, the corners have no structural benefit as they carry no load. Now if top and bottom gussets were used, then additional structural support would be provided. The statics and solid mechanics of the structure make the corners the strongest part. Angle pieces are susceptible to torsional loads, but the internal beams stiffen any torsional loading the structure would take. If you draw up a free body diagram it becomes clearer.
I can't take much credit for this, I just copied it from 469 with a few tweaks. I would say it worked pretty well for them, world championship and such things. Not sure any one was questioning the reliability of their drive train, hats off to them, they are an inspiration to all teams.
