Go to Post SELECT YOUR STRATEGY BEFORE YOUR ROBOT DESIGN. - Kims Robot [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 28-10-2014, 13:04
Math Quiz 5
This one requires multiple skills and tools, including calculus.
Given:
1) y = b - a*x2 (b>0, a>0, y>=0)
2) the total length of the curve is 10
Problem:
Find the value of b which maximizes the closed area between the curve and the x axis.
Unread 29-10-2014, 00:17
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Math Quiz 5
Spoiler for arc length:
Well (I think) I've got (2 sqrt(4(ab)^2 + ab) + arcsinh(2 sqrt(ab))) / (2a) = 10 from the arc length restriction, but I have no idea how to get that in terms of either a or b. I'm pretty tired, so I'll take another look tomorrow sometime not after midnight. Once you have a nice relationship with a as a function of b or vice versa it should be easy to optimize. Maybe a nice function doesn't exist though, not sure.
Also, it's pretty easy to get a as a function of ab, I'll have to think about if that's actually helpful though. Might be able to get the inverse of it.
Unread 29-10-2014, 17:49
FF TSL: Frog Farce
Re: Math Quiz 5
Spoiler for solution?:
Ok, next I defined a variable c=ab, and got a as a function of c using the arc length. I also got area as a function of c. Then, because the derivative of the area is some insanely long expression, I put it into my CAS and got the answer ab = 1.515, a=.817 and b=1.853.
EDIT: somewhere I lost a factor of two, the actual answer is:
Spoiler for actual solution:
a=.626, b=4.06
Unread 29-10-2014, 18:39
Re: Math Quiz 5
Originally Posted by Bryce Paputa View Post
a=.817 and b=1.853
Plug those numbers into your arc length expression and see if you get "10".
a=.626, b=4.06
Plug those numbers into your area expression and tell me what you get.
Unread 29-10-2014, 18:57
FF TSL: Frog Farce
Re: Math Quiz 5
Spoiler for area:
12.927. Also noticed that, approximately, a*sqrt(a) = 1/b * sqrt(b). Not sure if that's a coincidence or if figuring that out gives an easier way to solve the problem.
Unread 29-10-2014, 19:07
Re: Math Quiz 5
12.927
Double-check your area formula.
If you're sure it's correct, please post it.
Unread 29-10-2014, 19:25
FF TSL: Frog Farce
Re: Math Quiz 5
Nope, it was wrong. Correct area, a and b are
Spoiler for answer:
a=.285, b=3.34, area = 15.2
Unread 29-10-2014, 19:50
Re: Math Quiz 5
Nice job.
Want some reps? Please post your work and explain each step.
Unread 29-10-2014, 20:14
FF TSL: Frog Farce
Re: Math Quiz 5
Here's how I did it: https://docs.google.com/document/d/1...it?usp=sharing
Unread 29-10-2014, 22:20
Re: Math Quiz 5
Very interesting approach.
On page2 of the Google doc you say "Assume dR/dc=0, Solve for c"... But I don't see dR/dc anywhere, and I don't see you setting dR/dc=0 and solving analytically for c.
It looks like you gave a(c), b(c), and R(c) to desmos, and let it figure out dR/dc (numerically?) and find the zero crossing to get the desired value of c. Yes? I'm not familiar with the desmos calculator so I'm guessing.
If you would add just a bit more explanation to the Google doc for the benefit of future readers that would be most helpful.
Unread 29-10-2014, 22:28
FF TSL: Frog Farce
Re: Math Quiz 5
That's correct, I did it numerically with the calculator. The Google doc now clarifies this. I'll look into an analytic solution.
Unread 29-10-2014, 22:39
Re: Math Quiz 5
It may not exist. My CAS choked on it.
Unread 29-10-2014, 23:01
Re: Math Quiz 5
Using your R(c) method, a numerical root finder quickly converges to a precise value for c.
But you can get the same result without differentiating R(c), by simply plotting R(c) and locating the extremum.
Name:	find_root dRdc=0.png
ID:	17422  Click image for larger version
Name:	find max R(c).png
Unread 29-10-2014, 23:09
FF TSL: Frog Farce
Re: Math Quiz 5
I get 3 arcsinh(2 sqrt(c)) * sqrt(4c^2+c) = 2c+8c^2. I doubt there is a nice closed form of this.
Unread 29-10-2014, 23:22
Re: Math Quiz 5
For completeness, here's how to solve the problem using constrained nonlinear optimization.
It's a bit easier to set up. All you need is the length and area as a function of a and b.
The area is the objective (to be maximized), and the length is a constraint on the values of a and b.
Name:	NLO solution.png
