Thread Tools |
Rating:
Display Modes |
Re: pic: FRC558's modified VEXpro Drive in a Day
Just curious, what is the benefit of that? To save weight? Smaller holes in the frame?
The tube axle becomes a frame member and dramatically increases the rigidity of that chassis section. When using the 3/8" bolts you can't tighten the bolts since that would bend the frame. With the tube axle setup you preload the bolts to achieve greater chassis strength.
Did you guys slit the colson wheels at all? Or run them stock?
Personally, I don't think the cost of implementation is worth the benefit of the added traction. Colsons are already up there in the traction world. They're just under blue nitrile if I remember correctly and slitting them still doesn't get them to nitrile's level. Their wear characteristics far outplay any wheel I've seen in FRC, though. |
Ideally in this configuration, you would use standoffs around the axle to provide stiffness. That adds more parts, more weight, etc. Not hard to do, but you are limited to using the mounting holes provided by the DIAD, chain routing, etc. Anyone have thoughts on using 3/8" steel rod as dead axles? Tap both ends of the axle and it'd be close to using tube axle/bolt. I wouldn't think a 1/4"-20 bolt would work...not enough thickness left in the rod. Something smaller like a #10 or #8...at which point you would have to drill all 4 holes in the DIAD sideplate, rather than using the pre-punched 1/4" hole for the outer wheels (of the 8wd)...but it could work. |
#7
As for maintaining proper wheel alignment & spacing - I'd recommend any solid non-deforming material for standoffs. The dark-grey plastic from Andymark works great (it's why it's in the KOP, or was last time I used a KOP). I agree that the axle itself should NOT be used to stiffen a frame. The only load you want on a wheel axle is normal to the floor so it rides correctly on the balls inside the bearing. |
#8
#9
You could turn down the ends of the 3/8" rod and thread them for 1/4-20. The major downside of this being that you'd need to remove the outside of the drivetrain if you wanted to change a wheel.
#10
I would worry about the 1/4" bolt elongating the mount holes after a rare hit - like one that tips the bot up a bit, then the bot slams back to the floor, or like what happens when coming down off of a ramp/bump. We experienced some of this in 2007. When we went back to this style of dead axle in 2011, we used 3/8" rods and also used 1" angle brackets (1/8" thickness) to mount the wheels below the 1x1 frame. This gave us flexibility to change a mount out if we had problems. The "look" of the drive train where we mounted the wheels was similar to the old IFI KOP frame rails. |
#11
Thanks for the feedback, feel free to keep the questions coming. FRC558 was extremely happy with our drivetrain's performance and reliability in the 2014 season. There is something to be said for being able to assemble during week 2-3 of build and not have to touch the drivetrain for 100+ machines.
RC, have these bearings been tested for load? I'd love to run these but I have concerns about testing new things in our drives. If these are more then capable, we'll switch over to them and the tube axle material for 2015. Last edited by jwfoss : 30-10-2014 at 09:54. |
#12
do you guys think that there's any chance that FIRST will move back to a max of 4 CIMs instead of 6 CIMs?
#13
It's a possibility. Or some rule limiting max power in drive.
#14
We can only hope! With the introduction of so many powerful motors available, it's simply lead to a drivetrain power "arms race".
- Mr. Van |
#15
To a point. For the majority of games, what matters most is what's on top of the drivetrain, and how it's used.
