Re: Math Quiz 5
Double-check your area formula.
If you're sure it's correct, please post it. |
Re: Math Quiz 5
Nope, it was wrong. Correct area, a and b are
Spoiler for answer:
Re: Math Quiz 5
Want some reps? Please post your work and explain each step. |
Re: Math Quiz 5
Here's how I did it: https://docs.google.com/document/d/1...it?usp=sharing
Re: Math Quiz 5
On page2 of the Google doc you say "Assume dR/dc=0, Solve for c"... But I don't see dR/dc anywhere, and I don't see you setting dR/dc=0 and solving analytically for c. It looks like you gave a(c), b(c), and R(c) to desmos, and let it figure out dR/dc (numerically?) and find the zero crossing to get the desired value of c. Yes? I'm not familiar with the desmos calculator so I'm guessing. If you would add just a bit more explanation to the Google doc for the benefit of future readers that would be most helpful. |
Re: Math Quiz 5
Re: Math Quiz 5
It may not exist. My CAS choked on it.
#8
Re: Math Quiz 5
Using your R(c) method, a numerical root finder quickly converges to a precise value for c.
But you can get the same result without differentiating R(c), by simply plotting R(c) and locating the extremum. |
#9
Re: Math Quiz 5
I get 3 arcsinh(2 sqrt(c)) * sqrt(4c^2+c) = 2c+8c^2. I doubt there is a nice closed form of this.
#10
Re: Math Quiz 5
For completeness, here's how to solve the problem using constrained nonlinear optimization. It's a bit easier to set up. All you need is the length and area as a function of a and b. The area is the objective (to be maximized), and the length is a constraint on the values of a and b. Last edited by Ether : 29-10-2014 at 23:33. |
#12
Re: Math Quiz 5
#13
Re: Math Quiz 5
