Go to Post Sleep... what is this sleep you speak of? - Choi9111 [more]
Unread 21-02-2003, 16:31
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Locking the clutch
Has anybody found a good method of locking this years clutch?
Unread 21-02-2003, 16:33
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Yeah, use CIM's
Unread 23-02-2003, 00:40
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
You really shouldn't need to. It's already pretty rock solid as it is.
Unread 23-02-2003, 01:44
Umm Errr...
JB weld!!!!
1139 Alumni
Unread 26-02-2003, 11:15
jmo8605's Avatar
jmo8605 jmo8605 is offline
jmo8605 is an unknown quantity at this point
Send a message via AIM to jmo8605
i've got the clutch in drive and it doesnt move out of drive but it does slip a little.
Jon
384
Unread 26-02-2003, 12:09
IVIaxor's Avatar
IVIaxor IVIaxor is offline
#0824 (SWAT Robotics)
IVIaxor is an unknown quantity at this point
Originally posted by Rickertsen2
JB weld!!!!
lol! Thats what we did until the JB weld sheared off. I designed a part for our team that fit over the front of the gearbox and provided positive locking between the last planetary ring and the plastic housing. Then, out of paranoia, we used a paper cup to create a shell of JB weld over the whole thing . Of course, we were sending the power of both the drill AND the CIM through that gearbox (geared the CIM up to the drill's speed)
"Poetry in stillness, Elegance in motion."
swatrobotics.org
Unread 26-02-2003, 15:04
jmo8605's Avatar
try this....take the plastic housing that holds the motor in to transmisson(not the motor mount). unclip it, turn it 180 degrees. then the plastic tabs should lock the selecter into low....it works fine. if you have any questions just write me back and ask
Jon
motor man
384
Unread 26-02-2003, 16:52
Parks Parks is offline
Parks is an unknown quantity at this point
transmission locking
We took the transmission apart to lock it into gear. Simple.
Then we decided that we might as well lock the transmissions out by machining parts as we did for the gear. Not simple.
Taking apart the clutch is not reccomended. We almost had aneurisms trying to deal with them. I did finally machine good parts, put them in there, then realized the final problem, getting everything back together. Getting that black clutch cover back on is hard.
Now that I know there is a simple way, I could just scream.
Aucum's razor: The simplest solution is usually the best.
Andrew Parks
CrescentSchool Robotics
Co-Construction Head and Driver
Team 610
2002 Regional Champs
2002 Engineering Inspiration
2003 Regional Chairman's Award
Unread 26-02-2003, 18:42
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Smile Clutch Lock
We have found a wonderfull way to keep the clutch in place and it is simple. WE simply put 3 wireties around the motor in front of the little wite notch to lock it in place, and it will not let it move.
P.S. It is for the drill motors
(K.I.S.S. Method)
"I'm sorry, after all he is just a wookie!"
Unread 26-02-2003, 19:51
David Lantz's Avatar
David Lantz David Lantz is offline
None #0118
David Lantz will become famous soon enough
Our team was forced to lock the "shifter" into place after we had a small accident and broke the plastic ring that encases the transmission. We simple drilled 2 small pilot holes in the side of the casing and then screwed two small bolts in behind the shifting parts not allowing them to move. Very simple and still working.
Those who say it cannot be done should not stand in the way of those who are doing it.
-Someone Famous
Unread 26-02-2003, 22:36
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
The white shifter is not the clutch.
Unread 26-02-2003, 22:38
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We used a hose clamp to hold it down. It was slipping all the time, but it works just fine now. It's a refined version of our old ziptie method.
Jeff Waegelin
Unread 01-03-2003, 21:17
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Oh, it wasn't paranoia. There was soo much power in that transmission, it sheared off the tabs that the custom aluminum rings used to attach to the motor transmission.
/me hopes that there's a factor of safety of at least 2 in that gearbox...
-=- Terence
(the grease monkey who designed 824's drivetrain).
Terence Tak-Shing Tam <ttstam@u.washington.edu>
Engineering Team Captain, SWAT Robotics
http://www.swatrobotics.org
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
Drill gearbox clutch Joe P Technical Discussion 3 12-03-2003 13:22
Drill motor clutch slippage - HELP??!! Mr. Van Motors 13 20-02-2003 15:49
Disabling drill transmission clutch Charlie B Motors 2 31-01-2003 10:02
Locking the drill motor clutch? Rick Gibbs Motors 1 06-01-2003 09:46
