Go to Post To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. - Al Skierkiewicz [more]
Unread 30-10-2014, 07:14
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Re: pic: Concept 6W Drive Train
Shafts were 7075 1/2 hex.
Sloppy is probably the wrong description, more flexible than anything. The top of the side plates had some decent flex in direction changes.
I like the suggestion for removing the upper inner support, ithink that could easily change depending on the game and mechanisms required.
Originally Posted by philso View Post
You may want to consider what would happen if this chassis is used in a game that allowed high speed and hard hitting, like this years. There is the possibility that the vertical angle pieces in the corners deform when hit on that corner causing the two outermost side tubes to move backward. Since it looks like your axles are supported by the lower side tube, they may bind in the bearing blocks and/or cause the robot to not drive straight.
That's a good point, it would help to add some reinforcement to support the lower beam alignment.
