Go to Post Defense is a good thing! - Kevin Sheridan [more]
Unread 30-10-2014, 19:25
Andrew Duerner Andrew Duerner is offline
FRC #5818
Andrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud of
Gearbox for mechanism or appendage
Let me start with a little background. I'm a professional mechanical engineer and I love robotics! I mentored for a team two years and went to several regionals and two championships. I also love solving problems and inventing. About seven years ago I came up with a new eccentric gearbox, it worked pretty well but it was too costly to produce. After being involved with FRC I started adapting the design to fit the competition requirements, low cost, available motors, ease of use, etc. After many iterations, kudos to the inventor of the 3D printer, I believe I have a design that can help a lot of teams improve their performance of the competition challenges.
Here are a few details on the gearbox. Its’ approximate size is 5”x5”x2” and weighs around 2lbs. It directly mounts a 2.5” diameter motor with a keyed 8mm shaft (CIM family). The base mounts to 1” 80/20 extrusion on four sides. The output has the same mounting provisions to make multi degree of freedom arms and gimbals easier. Right now there are three ratio options, 552:1, 264:1, and 168:1. There is an integrated bearing track approximately 4” in diameter to support the output load. Right now gearbox is made of ABS plastic fabricated on an FMD 3D printer. I believe this will be plenty strong for competition if it is installed correctly and used to manipulate game pieces, not for taking the load of an opposing robot crashing into you (which is true for many mechanisms in FRC). If the demand is warranted I could see transitioning to injection molded parts with better plastic to be stronger and cheaper. As for cost for the current design, I’m trying to keep it under $100.
This effort was directed at the general FRC community. I know that some “elite” teams fabricate all of their own gears and can machine anything they want ending up with something better suited for the competition, but there are many teams that I saw coming to the competition with a drive base and limited game functionality. I really want to help elevate teams to have success with their available resources.
Special thanks to Chase (also an FRC mentor) for help with cost cutting ideas and general improvements along the way.
I attached a picture of one mounted with some 80/20. If anyone has feedback or is interested in more information please post below or send me a PM.
Thank you,
Andrew
Name:	gearbox, 168 to 1.jpg
Unread 30-10-2014, 20:43
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Gearbox for mechanism or appendage
$100 for this is a very good price, although I'm wondering how you're getting past the cost of what I assume is a 2 stage planetary transmission. Best of luck in your endeavors.
Unread 30-10-2014, 20:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Look up eccentric gearbox...it's not planetary. I'd love to see the insides of this....
Unread 30-10-2014, 21:01
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Do you have estimates on backlash and efficiency numbers?
Unread 30-10-2014, 22:16
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
I second this. This looks pretty slick.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 30-10-2014, 23:29
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Oh whoops, I missed that part of the description. Planetary seems more "normal" to me for large reductions.
Unread 31-10-2014, 10:42
MrForbes's Avatar
AKA: Jim
I'd like to see a "harmonic drive" that's affordable enough to use on one of our robots....
Unread 31-10-2014, 12:35
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
... I'd love to see the insides of this....
Excellent questions.
Any chance you can provide these?
Unread 31-10-2014, 14:23
FRC #5818
Good questions.
The backlash is somewhere around 1-3 degrees.
As for the efficiency, I really don't have the right equipment to measure that right now. It is abs plastic and it's not melting, if that's saying anything.
Attached is a picture showing whats going on inside. The gearbox ended up being pretty simple, kind of ironic considering the path it took to get to this point.
-Andrew
Name:	gearbox inside.jpg
Unread 31-10-2014, 14:28
Michael Hill's Avatar
Do you have any maximum torque figures?
Unread 31-10-2014, 15:03
AdamHeard's Avatar
Lead Mentor
How can we buy one?
Unread 31-10-2014, 16:32
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
How can we buy one?
2nd that.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 31-10-2014, 17:17
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
How can we buy one?
Try Harbor Freight. Link to old thread. Other link.
Richard Wallace
since 2003
Unread 31-10-2014, 21:03
President, VEX Robotics, Inc.
This gearbox is known in the industrial robotics industry as an epicyclic gearbox and is very common in robots that require low backlash and high gear reduction.
A couple of business and technical points:
1. There are MANY patents on this design. Several of them have expired but a few key ones still exist so do a patent search before selling this.
2. This design looks to only have one stage going in a single direction. This will induce severe oscillations that cause torque ripple which are detrimental to high load arm applications. There are ways to solve this but it adds significant cost.
3. In order to get acceptable efficiency the oscillating gear must have a very smooth surface finish. Grinding that surface is a must or I would not use it. Plastic gearing for this will severely limit the load carrying capability.
That's all I can think of now.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 01-11-2014, 03:04
FRC #5818
Michael, I torqued the gearbox unpowered with some lever arms until it broke apart. I would estimate that it reached around 50 ft-lbs.
Adam, I built a website, I'm a mechanical engineer so no making fun of it looking like its from 2004, I need to go through the rules on mentioning trademarked names or just delete them, after I do that I'll post the website address and they can be purchased through the Paypal payment system with a credit card.
Paul, I did some patent searching, I couldn't find anything that the design violated, If you know something in particular that may be a problem I would welcome any information. I haven't experienced oscillations besides having to counterweight the input cam/oscillator. Plastic gears do have their limits, obviously I wouldn't recommend this for an industrial robot, but for FRC robot that needs to run for limited amount of time, I believe it can work.
-Andrew
