Go to Post Once you know where you want to go, you can decide how you want to get there. - sciguy125 [more]
Unread 01-11-2014, 19:56
Nate Laverdure's Avatar
FRC #2363
Re: pic: 1885 Drivetrain
EtherSim looks real good, Jesse. Looking forward to playing with it.
Originally Posted by 75vs1885
80/20 for the adjacent sides
These sides play an important role on a typical WCD chassis-- they are the major contributor to the frame's torsional stiffness. So with that in mind, why do you suppose you typically see a lot of 2"x1" tube here, as opposed to 80/20?
Unread 02-11-2014, 21:34
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Very nice! Using 8020 for the cross bars is an interesting idea. It might be slightly heavier than a 1x2 tube, but it would be much faster to fabricate than the tube and bracket method we use (from the team 221 superlight chassis). It eliminates 2 fabricated parts and allows the use of 1/4-20 hardware rather than #10 hardware at the corners.
I also like the vex bearing plates for the outer wheels. Another nice fabrication time saver. It's funny, we were just discussing this idea at the FRC summit at ODU on Saturday. One question, does the use of the vex bearing plates allow the chains to be moved inside the side rails?
To spark some ideas, check out the video of the presentation I gave on the evolution of the Triple Helix west coast style drive trains. Any chance you will have your drive train at the FRC workshops in Richmond?
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 03-11-2014, 08:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The 80/20 was an accidental "innovation". We had plates made for riveting, then found out we used all of the rivets on something else, and then we lost one of the plates. So rather than delay another session, Stephen and I came up with the idea for the 80/20 while looking through our stashes of metal tubing. It won't make the cut for a production robot (80/20 can't be powder-coated) but for a prototype it's pretty nice.
The VEX bearing plates are not counter-sunk, so the flanges are completely on the outside of the plate. Since there is 1/4" worth of bearing plate on the outside of the tube, this means there is a nice round 1" of axle between the live bearings inside the tube. If you can fix 2 #25 chain runs inside that (subtract the walls, of course) then there's nothing stopping it.
Edit -- ooh, just thought about it - you'd have to 'nix the WCP bearing block on the outside of the direct-drive gearbox in order to run chain in the tube. This means you're responsible for your own alignment of the gearbox to the frame rail. There are 3 major reasons why I really like the WCP & VEX block combination, and this natural alignment is one of them.
I and my team are pre-occupied with a 48 team FLL tournament the Saturday of the Richmond workshops. I'll be out of town the Saturday of the 1418 workshops. I actually wanted to present a lecture on drive trains and over the summer designed the schedule for this prototype to be ready in time for the workshops. Then we got our FLL dates . I'd do it if I weren't head judge or head ref.
