Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 03-11-2014, 10:38
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
pic: Team 3572 Chassis Project
Unread 03-11-2014, 10:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Team 3572 Chassis Project
I really like most of the ideas behind this configuration. There is only one major modification I would make: Cantilever the middle wheels and remove the bent bracket on the outside altogether.
This bracket looks like it will receive all of the load that the wheels will put onto the frame. Its one major weakness is that it will most likely flex/bend in the direction parallel to the drive wheels when the robot is fully loaded at 150lbs or pushing/resisting another 150lb robot. This can be mitigated by adding angle supports along the outer frame, yet a steel cantilevered axle will handle it just as well without the extra parts.
I'm still mulling over how other pieces would react to the various forces imparted upon them during a match, but nothing jumps out at me at the moment.
Unread 03-11-2014, 10:53
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
It's hard to tell from this angle, and I assume you checked this already, but it looks like the belts to the outer wheels might interfere with the CIMs.
Also, I can't really tell what's going on with the outer wheel axles, the hex looks like it just kinda merges with the 2x1 with no bearing, and on the oppisite side looks like it has been turned down to 1/4in or something.
...wait...
Those are bolts aren't they lol, I have never seen someone cantilever bolts before, you might get some wobble if the threads are going through a bearing because the diameter won't be exactily that of the bearing or the tube they are running through...
You might also consider adding a 3rd CIM in the center with a shorter belt and widening the pulley to accommodate.
Those plates give me a bit of pause, you may want to brace them, but its worth a try in the off season.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 03-11-2014, 11:25
Design isn't totally done yet. We were thinking of cantilevering the front and rear wheels and running dead axles with a support block inside the frame rail to make it solid. We would also use smooth shank fasteners.
We have never done this before, so our big fear is building something with weak points. That's why we plan on building it now and refining until 2016. The brackets around the center drive portion are to keep everyone happy, the big debate has started with us between cantilevering the whole thing or keeping those in to make sure the hex shafts stay aligned.
The belts miss the CIMs by .100 gap.
A major goal of this was to be able to build it with what we have in our shop currently. It's killing me that we have to send the rails off somewhere to get them machined for us as we don't have capacity to do it ourselves (a drill press just isn't that accurate, and drills don't make very good holes for bearings).
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 03-11-2014, 11:29
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Can you explain the theory behind your locations of your 8 wheels?
I'm curious about your choice in spacing the two center wheels so close together, thanks.
Unread 03-11-2014, 11:35
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
What is your belt wrap for the stage off of your CIMs going to look like? If that is one belt tangent to the outside of all 3 pulleys, then I would question if you have enough belt wrap on the driven pulley in that arrangement.
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'd suggest increasing that clearance. There will be some motion in the belt while spinning, and it may end up touching the CIM with only 0.1" clearance.
Unread 03-11-2014, 11:42
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
I really don't trust the outside wheels. Our team made a minibot with cantilevered wheels on 3/8in bolts and despite it being substantially lighter than an FRC robot it could not handle the forces. Your wheels are also cantilevered out further than our minibot and are not on shock absorbing pneumatic tires leading me to trust this even less.
Also, you need blocks on the inside of the 2x1 to prevent the wheel bolt from just crushing it.
Unread 03-11-2014, 11:44
We have always been a 6WD team, and have gotten pretty good at balancing the robot right on the center wheels. The thought was that we would have less tip to the robot this way by keeping the distance between the outer and inner wheels as big as possible. And in keeping the middle two tight together we get direct driven gearing, and we can run like a 6wd that has a wider balance point and two extra wheels for more contact with the carpet.
We are going to run two 9mm belts from the motors, We tried the full wrap on a single belt and had a lot of engagement issues. Only four teeth were in contact on the main pulley.
a little belt slap is fun though right? We will be able to move the motor plates a bit in our final production. Those plates we will plasma cut in house so we can always make them taller and closer to the center drive unit.
Andrew Basse
Unread 03-11-2014, 11:46
Thanks for the tip, that is my biggest concern as well. We do plan to run solid blocks in the frame, either wood or UHMW as we have a big chunk left from last year. I want to learn as much as possible from this, so that our kids can learn as much as possible from this, so we are trying a lot of new things.
Andrew Basse
Unread 03-11-2014, 11:47
nathannfm's Avatar
AKA: Nathan
FRC #3940
Oh, I didn't even consider he might be thinking this, don't do it! You want a very minimum of six teeth in total mesh and at least 60 degrees of belt wrap. I am pretty sure we had a bit more of both of those on our drive this year and even under extreme tension they would still ratchet. If you need a wider pulley I suggest http://www.vexrobotics.com/htdversapulley.html you can add slices to increase with width.
Unread 03-11-2014, 12:01
With two 9mm belts I think we'll be okay as long as we get the tension right.
Andrew Basse
Unread 03-11-2014, 15:22
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
looks like the cims would interfere with the bumpers, and they could get damaged if hit to hart from another robot. Is there an advantage to having them pointing outside opposed to inside?
Other than that it seems really solid.
btw, would the electronics board be mounted underneath?
Unread 03-11-2014, 15:42
Made a few updates. Looks pretty much the same but added in blocks for the front and rear axles. Also bumped the motors up and over to give .25" clearance for belt movement. Also I removed the braces on the outside of the frame to cantilever the wheels and added retaining bolts on the axles.
I'll try to add belts tomorrow so the clearances can be seen better.
http://imgur.com/Xw2xC0l
Andrew Basse
Unread 03-11-2014, 15:45
bumpers would mount on the outside of the CIMs, but mounts haven't been figured out yet. Putting them outside gives a huge amount of space to get all of our electronics down as low as possible in the frame. We are trying to get back to our 2013 design where our center of gravity was about 4 inches off the floor. Having the battery lay down in the middle of the robot makes that pretty easy.
We have always only used around 13-14 lbs of bumper, a more ridged attachment frame that eats up around 5 lbs of bumper weight could be all the protection the motors would need, I hope...
Andrew Basse
