Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 02-11-2014, 20:39
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Introducing Revolution Pro...crab/swerve module
Some of the pictures on the product webpage don't seem to match the main product picture or the PDF. ( http://www.team221.com/upload/king_crab_detail.jpg )They apparently use the older revolution swerve design at least for this pic. (and I doubt that the new design would even work on this platform because it's so much shorter, no height for a CIM)
Also the PDF shows the input as 3/8 keyed shaft while the product picture ( http://www.team221.com/upload/revolution_pro.JPG) has a hex input.
Uploading a CAD model would explain these discrepancies I'm sure.
Reply With Quote Multi-Quote This Message Quick reply to this message
Good observations. The image on the main page is of the original prototype. It had a 1/2" hex input on the vertical drive shaft. The production version sticks with the 3/8" keyed shaft.
The images of the complete robot are really just for reference. We just finished building it...it used a classic module. The new modules aren't quite ready.
I will post some step files soon.
Am I the only one who thinks both the new module and the new platform they built are disturbingly similar to designs I've posted here within the last year?!
Many posters in this thread have addressed your statements. Unfortunately I haven't seen your designs. I'm sure they are similar in many ways...as are most swerve derivations...but this is definitely a coincidence.
As for the platform design, I did my first one in 2010. I slowly modified and improved the design over the years. You can see our custom creations here.
http://www.team221.com/order.php?cat=10
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 02-11-2014, 21:12
magnets's Avatar
magnets magnets is offline
Originally Posted by Bryce2471 View Post
My observation was more based on the large amount of optimizations that appear in my posted designs. Not on completely brand new ideas that have never been seen before.
You pointed out that your designs were disturbingly similar, implying that the Revolution swerve module had somehow copied yours.
1. It uses a small diameter solid treaded wheel.
Excluding 2009, show me a swerve drive that does not use a wheel with a tread. Teams have been using small wheels since 2008 (http://www.chiefdelphi.com/forums/sh...ad.php?t=64824)
Here's a team using a 3" wheel: http://www.chiefdelphi.com/media/photos/38289
2. The wheel is off set slightly to one side so it can be nested by the miter gear.
See 148 in 2008. The wheel is off center in that design.
3. It utilizes straight cut gears instead of a chain to transfer power to the wheel.
See 148 again.
Or this one: http://www.chiefdelphi.com/media/photos/37005
4. It uses a dead axle to keep side plates light weight.
See this design: http://www.chiefdelphi.com/media/photos/34443
Or any 118 robot since 2005.
5. The wheel axle is a hallow stand off to increase the strength of the module and make replacing the wheel easy.
See the old revolution swerve design.
Also, this drawing shows that their wheel axle isn't hollow. (http://www.team221.com/upload/445-Revolution_Pro.pdf)
1. It uses a single extrusion upper frame.
221 Robotic Systems has used this frame before you have.
2. It's CIM motor is behind the steering motor, in an in-line configuration.
Where else would you put the steering motor?
3. CIM chain runs around the steering shafts to get to the main double shaft.
118 has done this in 2007.
Excluding this and Aren Hill's in wheel CIM swerve, most swerve designs are very similar, or fall into a few categories.
Unread 02-11-2014, 21:26
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I'm sorry, that's not what I was trying to imply.
I'll quit posting in this thread now, sense it seems like I'm just making it worse.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 02-11-2014, 21:30
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Alright guys, give him a break. I think he gets the point.
Andrew, I'm loving the updated design! Seems very efficient and compact. If I'm ever on a team considering swerve again it'd definitely be the top candidate. The updates have really modernized the design, and I really like that it shows off what you can do with mostly COTS parts.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 02-11-2014, 21:51
Jared's Avatar
Jared Jared is offline
Agreed with both points -most swerves are quite similar anyway.
I really like this design. It's just simpler and smaller.
Unread 02-11-2014, 22:07
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Nice, we used the Revolution modules for our swerve this year.
I see that you ditched the chain connecting the wheel to the top part thingy. I like that; we have had a bit of problems with the chain coming off.
Head Programmer / Driver
Unread 02-11-2014, 23:29
Aren_Hill's Avatar
Build Nifty Things
Excluding
Entertainingly enough, I sent a concept to Kevin back in April of this layout, he just made a 2 speed version and posted it first.
I'll post mine sometime in the near future.
-Aren
A guy who likes robots.
Unread 03-11-2014, 08:45
AKA: Anthony Lapp
STEP files are now posted.
http://www.team221.com/viewproduct.php?id=147
Anthony Lapp
RobotOpen
Unread 03-11-2014, 10:28
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Originally Posted by ajlapp View Post
Thank you so much for this, I took a cross section and noticed there is a 1/2"id bearing right above the vertical bevel gear that doesn't seem to be doing anything. If it were 3/8 it would be guiding the shaft which would make sense, am I missing something? I also noticed there are no thrust bearings anywere, only thrust bushings, I guess you have found this to be acceptable?
Also, in the prototype with the hex shaft sticking out the top how did you manage to assemble that without using larger diameter hex bearings and thus a larger overall diameter?
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 03-11-2014, 10:50
AKA: Anthony Lapp
Looks like a modeling typo. It's the same 3/8" ID bearing shown at the top of the stack. Thrust bushings are the answer. We used them on the classic Revolution and they performed great. Actually a lot of swerve guys think you can send the thrust loads directly into the ID of the bearing....I like the additional overhead that the bushing provides.
The shaft was 1/2" hex to 1/2" round to 3/8" hex. It used a 1/2" ID x 7/8" OD bearing....the same one incorrectly shown in the model actually. Vexpro sells them. We changed back to the keyed shaft as the original design was cost prohibitive.
I've updated the model with the correct bearing.
Anthony Lapp
RobotOpen
Unread 03-11-2014, 11:53
nathannfm's Avatar
AKA: Nathan
FRC #3940
The fact that a shaft like that was actually created makes me smile, I never even considered that lol
Unread 03-11-2014, 11:58
AdamHeard's Avatar
Lead Mentor
You'd love every one of the shafts on our 2012 robot then.
Unread 03-11-2014, 12:28
nathannfm's Avatar
AKA: Nathan
FRC #3940
I really need to look at your CAD more
*finds 2012 drive*
I...wow, that drive...all questions, no answers...
https://imgur.com/qubH6NJ
Unread 03-11-2014, 12:32
AdamHeard's Avatar
Lead Mentor
*finds 2012 drive*
I don't think our 2012 ever got posted, but I should get on that.
What you linked is one of our WCD drive shafts. Fun part. We generally have a sponsor make them, but we've had students make them (and similarly complex parts) in house on our manuals.
