Go to Post When I got home from work my facebook wall had exploded with people chanting the names of dead scientists. Did someone say culture change? :cool: - Ian Curtis [more]
Unread 03-11-2014, 12:01
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: pic: Team 3572 Chassis Project
Originally Posted by nathannfm View Post
Oh, I didn't even consider he might be thinking this, don't do it! You want a very minimum of six teeth in total mesh and at least 60 degrees of belt wrap. I am pretty sure we had a bit more of both of those on our drive this year and even under extreme tension they would still ratchet. If you need a wider pulley I suggest http://www.vexrobotics.com/htdversapulley.html you can add slices to increase with width.
With two 9mm belts I think we'll be okay as long as we get the tension right.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
