Go to Post rebound rumble didn't really have a lot of rebounding or surprise earthquakes. - Rynocorn [more]
Unread 21-02-2003, 22:26
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Unhappy Exploding 884s
Okay, now that the robot shipped, can someone tell me what happend?
This year we are using 4 motors to drive two seperate gearboxes. Everything was running fine and dandy until we decided we wanted to try and recalibrate the speed controllers. Trying to be expedient about it, we pressed the calibration button simultaneously on two speed controllers that control one gear box and after a second or two, one of the speed controllers blew up. Not having a clue about what happend, we tried pushed the calibration buttons on the remaining speed controllers and another one blew up. What gives? In three years, we've never had this happen before and to my knowledge, there are no metal chips in the electronics as we carefully assembled the electronics after we machined everything?
What gets me, is that it was running fine and only when we pushed the calibration buttons that two speed controllers decided to die. I can see one speed controller failing out of a manufacturing defect, but two?
Unread 21-02-2003, 22:52
D.J. Fluck
Posts: n/a
Wow, Ive never heard of anything like that before...but I think you should contact IFI about that
Unread 21-02-2003, 23:20
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
not to make light of this situation because i can only imagine how much this must of sucked and how much this musta freaked you out....
but did they actualy explode? Cuz i would love to see a video of a victor actualy EXPLODE like violently with pieces flying everywhere....
On another note...
We did calibrate our victors but we had issues with it and so on the suggestion of users on this board we reset them to default calibration because we found it really didn't help but instead hurt the response of them, especialy in autono mode.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 23-02-2003, 22:17
We calibrate speed controllers each year in the current robot, to be sure they are working properly with the interface and all parts. I have never heard of a team trying to calibrate two speed controllers at the same time. At best this sounds like a dangerous practice. It is best to remove all circuit breakers except for the the controller that is being calibrated. Then you must remember that the controller does not store the calibration points until the button is released. The cal button must be pressed and held while the joystick is moved from extent to extent and while it is allowed to rest in the center position. We will not release the cal button until a "hands off" (no one touching the stick)verbal acknowledgment has been received.
Can I assume that since these controllers are feeding the same gearbox that you are running them from the same PWM output? Is your mechanical design capable of running with one motor disabled? Of course, if one motor is calibrating and the other motor is powered down, there should be no problems. I suspect that what may have happened is that one of the cal buttons was momentarily released during the cal process and it would have tried to supply full output to a locked gearbox.
Unread 23-02-2003, 22:34
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
Oh crap....
this post just reminded me that I totally forgot to calibrate the victors this year. Oh well, yet another thing that needs to be done at regionals
Oh and sorry for this useless post, I have no idea why your victors are exploding, although I have experienced a similar occurrance. Last year we had a short and the victor went up in a big puff of smoke.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 24-02-2003, 08:21
yah smoke sucks...we had one go up in smoke last year the first time we fired up the robot....first time our team had seen magic smoke in its existance and scared the crap outa most everyone....and that smell...that horrible Victor smoke smell...
Unread 24-02-2003, 09:26
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Smoke is bad? Nnooo - Electronics run on smoke! The trick is not letting the smoke out. If you let the smoke out of the electronics, they don't work any more.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 26-02-2003, 22:22
Iain Iain is offline
Iain is an unknown quantity at this point
They don't call it "the magic smoke" for nothing, yep.
Unread 26-02-2003, 23:51
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
What do teams calibrate the victors for?
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 27-02-2003, 00:37
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I'm going to try to explain this from a programming standpoint.
The speed controllers are already set to have a value of 127 being neutral, 255 full forward and 0 full reverse. However, if you look at the debug output by the joysticks, they usually hover around 245, because the plastic housing is in the way. Therefore, unless you calibrate the speed controllers, your robot will never see full power.
By calibrating, it sets the full power of the speed controller to be whatever you tell it to be. If you go into calibration mode, and move the joystick full forward and full reverse (example: joystick of 245 and 10), then those values will be the new range. Anything beyond those values will also be full forward (so it would still be safe to send it a value of 250).
Remember to return the joystick to center position before releasing the button, because the very last value it reads is recorded as neutral.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 27-02-2003, 00:50
Simeon Simeon is offline
#0820 (DeltaTech)
Simeon is an unknown quantity at this point
our victors haven't exploded, but one of our spikes did
something smelled funny
then after like 1/2 an hour we found that the little resistor thing on the side had totally melted...
the fuse was perfectly fine tho.
Unread 27-02-2003, 08:17
are u sure you had the polarity of the wires hooked up right?
Unread 01-03-2003, 21:03
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Smile
We've done this for the past two years and never had a problem. Why would it be a dangerous practice?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 01-03-2003, 21:10
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
It's just not a good idea to be messing around with lots of things at the same time. It's safer if you just calibrate one at a time.
Jeff Waegelin
Unread 01-03-2003, 23:20
Manoel's Avatar
Yes, but picture this:
We use a drill and an atwood to power each track of our robot. Those joysticks have some travel issues (eg. sometimes full forward is 254. Now center it back and put it forward again. You may get something like 240) and it wouldn't be nice to have the motors carefully set to the same speed with gearboxes and see everything fail because a victor ain't sending the same signal to each motor. That's why we calibrate FOUR victors (two for each side) at a time - we need many hands, though
Brazilian Machine
Team # 383
Suicidal Victor 884's... Caleb Fulton Technical Discussion 29 10-02-2003 09:48
