Go to Post The Tesla came in the blue tote. This is why you should always inventory your KOP before the replacement window closes! :p - sparrowkc [more]
Unread 03-11-2014, 15:42
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: pic: Team 3572 Chassis Project
Made a few updates. Looks pretty much the same but added in blocks for the front and rear axles. Also bumped the motors up and over to give .25" clearance for belt movement. Also I removed the braces on the outside of the frame to cantilever the wheels and added retaining bolts on the axles.
I'll try to add belts tomorrow so the clearances can be seen better.
http://imgur.com/Xw2xC0l
Andrew Basse
Coach - FRC Team 3572 - Wavelength
