Go to Post The Chairman's award is about doing what you can to strengthen the FIRST community. It doesn't require money to simply lend tools, wise advice or a hand. - Koko Ed [more]
Unread 04-11-2014, 18:10
MaestroRoboto's Avatar
MaestroRoboto MaestroRoboto is offline
AKA: Hiren Bhavsar
FLL #0020 (The Rocketeers)
MaestroRoboto has a spectacular aura aboutMaestroRoboto has a spectacular aura about
Can someone explain this code?
Could someone explain what is going on in this code?
public class Drivetrain {
Talon talon1 = new Talon(1);
Talon talon2 = new Talon(2);
Talon talon3 = new Talon(3);
Talon talon4 = new Talon(4);
Talon talon5 = new Talon(5);
Talon talon6 = new Talon(6);
DoubleSolenoid shifter = new DoubleSolenoid(1, 5, 6);
Encoder leftEncoder = new Encoder(10, 11);
Encoder rightEncoder = new Encoder(13, 14);
public Drivetrain(){
leftEncoder.start();
rightEncoder.start();
//DigitalInput port14 = new DigitalInput(14);
public void arcadeDrive(double moveValue, double rotateValue){
double leftMotorSpeed = 0, rightMotorSpeed = 0;
rotateValue = -rotateValue;
moveValue = limit(moveValue);
rotateValue = limit(rotateValue);
if (moveValue > 0.0) {
if (rotateValue > 0.0) {
leftMotorSpeed = moveValue - rotateValue;
rightMotorSpeed = Math.max(moveValue, rotateValue);
} else {
leftMotorSpeed = Math.max(moveValue, -rotateValue);
rightMotorSpeed = moveValue + rotateValue;
} else {
leftMotorSpeed = -Math.max(-moveValue, rotateValue);
} else {
rightMotorSpeed = -Math.max(-moveValue, -rotateValue);
//Setting talon values
talon1.set(-rightMotorSpeed);
talon2.set(rightMotorSpeed);
talon3.set(rightMotorSpeed);
talon4.set(leftMotorSpeed);
talon5.set(-leftMotorSpeed);
talon6.set(-leftMotorSpeed);
protected static double limit(double num) {
if (num > 1.0) {
return 1.0;
if (num < -1.0) {
return -1.0;
return num;
public void highGear(){
shifter.set(DoubleSolenoid.Value.kReverse);
public void lowGear(){
shifter.set(DoubleSolenoid.Value.kForward);
public void brake(){
public int getRightDistance(){
//return port14.get();
return rightEncoder.get();
public int getLeftDistance(){
return leftEncoder.get();
public void resetEncoders(){
leftEncoder.reset();
rightEncoder.reset();
