Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
Unread 04-11-2014, 18:10
MaestroRoboto's Avatar
MaestroRoboto MaestroRoboto is offline
AKA: Hiren Bhavsar
FLL #0020 (The Rocketeers)
MaestroRoboto has a spectacular aura aboutMaestroRoboto has a spectacular aura about
Can someone explain this code?
Could someone explain what is going on in this code?
public class Drivetrain {
Talon talon1 = new Talon(1);
Talon talon2 = new Talon(2);
Talon talon3 = new Talon(3);
Talon talon4 = new Talon(4);
Talon talon5 = new Talon(5);
Talon talon6 = new Talon(6);
DoubleSolenoid shifter = new DoubleSolenoid(1, 5, 6);
Encoder leftEncoder = new Encoder(10, 11);
Encoder rightEncoder = new Encoder(13, 14);
public Drivetrain(){
leftEncoder.start();
rightEncoder.start();
//DigitalInput port14 = new DigitalInput(14);
public void arcadeDrive(double moveValue, double rotateValue){
double leftMotorSpeed = 0, rightMotorSpeed = 0;
rotateValue = -rotateValue;
moveValue = limit(moveValue);
rotateValue = limit(rotateValue);
if (moveValue > 0.0) {
if (rotateValue > 0.0) {
leftMotorSpeed = moveValue - rotateValue;
rightMotorSpeed = Math.max(moveValue, rotateValue);
} else {
leftMotorSpeed = Math.max(moveValue, -rotateValue);
rightMotorSpeed = moveValue + rotateValue;
} else {
leftMotorSpeed = -Math.max(-moveValue, rotateValue);
} else {
rightMotorSpeed = -Math.max(-moveValue, -rotateValue);
//Setting talon values
talon1.set(-rightMotorSpeed);
talon2.set(rightMotorSpeed);
talon3.set(rightMotorSpeed);
talon4.set(leftMotorSpeed);
talon5.set(-leftMotorSpeed);
talon6.set(-leftMotorSpeed);
protected static double limit(double num) {
if (num > 1.0) {
return 1.0;
if (num < -1.0) {
return -1.0;
return num;
public void highGear(){
shifter.set(DoubleSolenoid.Value.kReverse);
public void lowGear(){
shifter.set(DoubleSolenoid.Value.kForward);
public void brake(){
public int getRightDistance(){
//return port14.get();
return rightEncoder.get();
public int getLeftDistance(){
return leftEncoder.get();
public void resetEncoders(){
leftEncoder.reset();
rightEncoder.reset();
Unread 04-11-2014, 18:25
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Can someone explain this code?
What behavior is it exhibiting that doesn't make sense?
It looks relatively normal, but could you add code tags around it so it preserves indentation? e.g.
printf("Hello World");
[ code ] opens
[ /code ] closes
(Eliminate the spaces from the tags)
Unread 04-11-2014, 19:46
AKA: Hiren Bhavsar
The code works fine, I just don't understand it and I am unable to contact the guy who wrote it.
The code shown is for a 6 wheel west coast drive bot
Unread 04-11-2014, 20:14
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Here's what I've interpreted so far. The rotate left/right may be flipped.
This is a rather strange convention.
It's probably trying to make sure the right motor is going faster than the left (i.e. turning left), but regardless this is probably not the ideal way to code this.
	//right speed controllers
	Talon talon1 = new Talon(1); //front
	Talon talon2 = new Talon(2); //middle
	Talon talon3 = new Talon(3); //rear
	//left speed controllers
	Talon talon4 = new Talon(4); //front
	Talon talon5 = new Talon(5); //middle
	Talon talon6 = new Talon(6); //rear
	rotateValue = -rotateValue; //x axis value from joystick. inverted to get the correct rotation direction
	moveValue = limit(moveValue); //y axis value from joystick. make sure its between -1 and 1
	rotateValue = limit(rotateValue); //make sure the rotation value from before is between -1 and 1
		//driving forward?
			//turning left?
		} else {
			//stopped or turning right?
	} else {
		//driving backward or stopped
			//turning left?
		} else {
	talon1.set(-rightMotorSpeed); //invert the front right speed controller (probably because the leads were swapped)
	talon5.set(-leftMotorSpeed); //invert the center left speed controller (probably because the leads were swapped)
	talon6.set(-leftMotorSpeed); //invert the rear left speed controller (probably because the leads were swapped)
		if (num > 1.0) {
			return 1.0;
		if (num < -1.0) {
			return -1.0;
		return num;
		//retract pneumatic
		//extend pneumatic
Unread 04-11-2014, 20:34
That part is a copy of the WPILib arcadeDrive method. You can see how it works here: http://www.chiefdelphi.com/forums/sh...0&postcount=11
Unread 06-11-2014, 16:45
AWoL's Avatar
AWoL AWoL is offline
Lvl. 225 Dark Code Mage (Java Type)
AKA: Adam Wolnikowski
FRC #0225 (TechFire)
AWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond repute
From a style and code neatness standpoint, might I suggest putting your right talons in an array and your left talons in another? Then you can set an entire side's speeds with a for loop like so:
for (int i = 0; i < left.length; i++)
   left[i].set(1);
or now with the roboRIO (Java SE 8), with a for each loop...
for (Talon t : left)
   t.set(1);
then put it in another method for easy use...
public void setLeft(int speed)
      t.set(speed);
or even a more general method for less code...
public void setSpeed(Talon[] tarray, int Speed)
   for (Talon t : tarray)
      t.set(speed);
and finally, work in the inversion...
      if (t.equals(talon1) || t.equals(talon5) || t.equals(talon6))
         t.set(-speed);
      else
         t.set(speed);
We handle setting our drivetrain speed in a similar fashion.
2016 Competition Results (Co-captain, Driver, and Lead Programmer; Junior)
Springside-Chestnut Hill District Event - WINNER / #2 Seed, #1 Seed's First Pick / Gracious Professionalism Award
Westtown District Event - WINNER / #1 Seed / Industrial Design Award
MAR District Championship - WINNER / #1 Seed / Industrial Design Award / Dean's List Finalist Award (Me)
World Championship, Carson Subdivision - QUARTERFINALIST / #3 Seed, #2 Seed's First Pick
Indiana Robotics Invitational - FINALIST / #14 Seed, #2 Seed's Second Pick
