Go to Post Real engineers don't need sleep... Just ask our bosses! - Mike Betts [more]
Unread 31-10-2014, 16:09
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
pic: Coaxial Swerve Drive Module with 2-speed Ball Drive and Nitrile Tread
Unread 31-10-2014, 16:11
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: pic: Coaxial Swerve Drive Module with 2-speed Ball Drive and Nitrile Tread
I like the synergy between a swerve drive like this and an 8 sided frame. Maybe I've said that before, but that extra length and width is a nice side benefit of your other efforts. What's the outer length and width of this frame?
Unread 01-11-2014, 00:56
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
What's the weight as shown in this picture (4 swerves and the chassis).
Unread 05-11-2014, 14:14
FRC #2451 (Pwnage)
29.625" square
We optimized for 2013 for a single large wheel shooter we ended up not using and it helped in 2014 for the large ball
38 pounds + fasteners not added to the cad file
Should be pretty accurate, all parts have correct materials.
Unread 05-11-2014, 14:27
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
I've seen teams who use swerve using their corners to hit other robots' corners and flip them in order to defend. Do you think your octagonal frame is going to be able to still do something like that?
Ready for the water games
http://i.imgur.com/QQXtifE.jpg
Unread 05-11-2014, 15:35
Is "flip" really the word you want to use, or would you like to choose another?
Unread 05-11-2014, 17:30
FRC #2451 (Pwnage)
It doesn't look like you have ever played at a competition with us so I don't understand your very specific question.
Did you have a bad experience this year with a octagonal robot?
We do not condone or encourage our drivers to be aggressive.
The octagonal frame does nothing to "flip" robots that I know of.
It's benefit is it maximizes area and wheelbase for a given perimeter.
It also rolls off another robot easier when they are trying to push you.
The question is, should a team be penalized when they build their robot with a low center of gravity and another robot that is top heavy gets flipped accidently?
Unread 05-11-2014, 20:09
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I think that Henrique means to spin, more like. Hitting a corner would give the maximum lever arm.
Unread 05-11-2014, 20:16
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Yes, I think he was referring more to a "spin," rather than a flip.
Does the octagonal frame give you greater ability to spin out when being pushed? I'd imagine it does.
This really looks amazing.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 05-11-2014, 20:44
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
29.625" square
With bumpers? That sounds a little low including the bumpers.
Unread 06-11-2014, 10:26
FRC #2451 (Pwnage)
Henrique, my apologies for misinterpreting your comment. The octagonal frame is more offensive than defensive. It is for getting out of a pushing match. You are correct, It would be harder to spin another robot with the octagonal frame. Really the design comes from maximizing the area of the robot for game pieces and mechanism.
Without bumpers the weight is 38 lbs.
Since bumpers don't count towards robot weight we set their cad files to zero pounds.
