Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 05-11-2014, 19:41
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
VEXPro 3-CIM Ball Shifter encoder?
We're looking at the Grayhill 63R series encoders for our VEXPro 3-CIM ball shifters.
Question what "Pulses per revolution" should we get? 256, 128, or 64? What are you using? Any issues with the high PPR? Will the new control system behave differently than the old?
Thanks!
- Mr. Van
Coach, Robodox
Unread 05-11-2014, 19:43
AdamHeard's Avatar
Lead Mentor
Re: VEXPro 3-CIM Ball Shifter encoder?
New and old system will handle the 256 no problem, get the most resolution you can.
Unread 05-11-2014, 19:48
Jared's Avatar
Jared Jared is offline
Thanks!
- Mr. Van
Coach, Robodox
The control system should be fine with all three resolutions.
That said, the 256 ppr encoders we have generate much noisier signals than the 64's. This becomes an issue if you're using PD control (specifically the d). The issue goes away if you use a low pass filter or turn on the FPGA's moving average feature (I think we averaged 4 or 8 samples).
Unread 05-11-2014, 20:05
The new control system has a much higher digital sample rate then the cRIO. This means that it can handle even higher resolution encoders, or have less noise in velocity measurements. However, due to phase error in the encoder, you will still want to use 1x decoding or 4x decoding with 4 sample averaging for velocity measurements.
Unread 14-11-2014, 12:53
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
We are almost done building our practice chassis and we have included encoders for the first time. We ordered the Grayhill 63R series 256 encoders.
The 4 sample averaging is a great suggestion that we will implement. I presume this is just reading the encoder in teleopPeriodic() and keeping a running average of the last n samples.
Can you elaborate on the 1x decoding or 4x decoding?
Unread 14-11-2014, 13:44
Aren Siekmeier's Avatar
on walkabout
All of the decoding happens in hardware in the FPGA, including the rolling sample average. All you need to do is configure the encoder object in your code to use 1x decoding or 4x decoding with 4 sample averaging as Joe suggests.
In Labview, this happens in Begin.vi when you call the Encoder Open block. In C++ or Java, these are either parameters for the Encoder object constructor method, or have corresponding set methods to be called after instantiation.
Unread 24-11-2014, 22:25
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
We are trying to source the wire and connector for the Grayhill 63r encoder (5pins) and the best/most appropriate way to connect this.
Anyone have an answer?
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 28-11-2014, 15:28
Gary Suter Gary Suter is offline
FRC #2439
Gary Suter is an unknown quantity at this point
Are the encoders in stock now?
