Go to Post Driving without the trailer was quite fun, but driving with the trailer was just painful. - Paul Copioli [more]
Unread 05-11-2014, 23:26
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
Exclamation [FTC]: Broken Fuse/Broken (Tetrix) Battery?!?!?!
Chief Delphi,
About a half an hour ago, our team was going to test out the electronics connections (battery pack, on/off switch, samantha, motor controllers, etc). When we flipped the switch to the "on" position, the lights turned on for two seconds, and then died. We kept turning it on, but none of the components (samantha, controllers, etc) worked.
We have wired the red wires together and the black wires together. Previously, this setup worked.
We are now trying to find the cause of this problem and the solution. We have ruled out the power of the battery because the charger says it has full power.
Could this be a fuse? What would the cause be? How do we fix it?
Regards,
The Charging Champions
