Go to Post I may not like the songs, but I love FIRST! :) - ScoutingNerd175 [more]
Unread 06-11-2014, 01:55
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Offsetting shifter piston?
I'm in the middle of making a small gearbox that utilizes the Vex ballshifter shaft. However, the cims are the first stage of gearing and go straight to the shifting shaft, and as a result the cims are so close to the shifting shaft that I can't fit the regular Vex shifting piston inline with the shifting shaft. Heck, I can't even fit a thin long piston there.
I'm faced with two options: Place the shifting piston behind the cims (~4.5" away from the shifting shaft) or to put the piston to one side and connect it by a bar to the shifting shaft. Is it dangerous to offset the piston to one side and use a metal bar to connect the piston to the shifting shaft?
Unread 06-11-2014, 02:06
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Offsetting shifter piston?
How much offset would be needed?
Or even better, a CAD drawing.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 06-11-2014, 02:07
Knufire Knufire is offline
5188 coupled a large bore cylinder off center to a ball shifter for our winch gearbox last year. What we found was that pulling so far off center created a moment and would cause the winch to occasionally jam and not disengage. This is a much different load scenario, so take it with a grain of salt. Our theory is that the only reason the system worked was due to the 2" bore piston used, simply brute forcing the mechanism to shift despite pulling so far off center.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 06-11-2014, 02:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Around 0.75" of offset. It's not too much I think.
CAD will be released in due time...
EDIT: more like 1.25".
Unread 06-11-2014, 03:00
Lead Bumper Mentor
AKA: Mike Marandola
That might work. Attaching the bar to the pancake cylinder will be easy since it has threads. You will just need to make the little bar as stiff as possible and try to eliminate most, if not all of the play at the spot where the bar attaches to the bearing on the shifting plunger.
Unread 06-11-2014, 03:05
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Okay, thank you. If it doesn't work out I can alwys switch to a different configuration.
Unread 06-11-2014, 10:03
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
[grandpa]
Back in my days, just about everyone's shiftin design incorporated offset pistons (team 45 being the notable exception). Granted, none of you whippersnappers use crash shifting designs these days.
[/grandpa]
Unread 06-11-2014, 10:13
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Pneumatic cylinders do not like moment (offset) loads. You can get away with it with short strokes & relatively light loading. Or you can add a rod & bushing that takes the moment letting the cylinder see only the axial load.
Unread 06-11-2014, 20:26
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
What do you mean bt adding a rob and bushing? Just to let them flex and spread out the moment?
Unread 06-11-2014, 21:21
EricH EricH is online now
Originally Posted by Lil' Lavery View Post
[grandpa]
[/grandpa]
[second grandpa]And that extended to the KOP shifters. You younguns think you've got it made with that single-speed gearbox and 6 CIMS? Back in my day, we got SHIFTING gearboxes in the Kit! And they shifted offset![/second grandpa]
And yes, those drill motor transmissions had to be shifted offset if you were going to shift. As I recall, my high school team ran a slider bar under ours to engage the shift ring and connected a short-throw cylinder to the other end.
This might be a good time to grab any engineering mentors you have and run through some numbers on buckling loads. I don't think it'll be too big of an issue, given a nice short distance and nice "light" load, but it's an opportunity to learn.
