Go to Post I have always gotten the answers I need. They're just not always the answers I want... - Alan Anderson [more]
Unread 06-11-2014, 14:52
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
evand4567 is an unknown quantity at this point
Re: Hexagon / Octagon frame with Swerve
Another concern with the swerve module (speaking from experience here): You might want to consider hex collars with a set screw and divet or some other stronger form of constraining your hex shaft (like roll pins), because the high amount of torque acting on the bevel gears will try to force the shaft and cause the collars to slip. Having the flange on the bearings facing inward helps, but it's still something you should address.
Unread 06-11-2014, 15:10
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The most often cited benefit of hexagonal and octagonal frames is avoiding friction pins/t-bones. Considering that a well programmed/driven swerve drive should already be able to accomplish this, I'm curious as to your reasoning for pursuing such a drivetrain.
Unread 06-11-2014, 16:57
Bryce2471's Avatar
Bryce2471 Bryce2471 is online now
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
It looks like your wheel axle has threaded holes on either end and bolts holding it to the side plates. I highly recommend that you change this to have a single through bolt. It will make removing the wheel much easier, and probably improve the strength of the assembly.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 06-11-2014, 20:53
You might as well ask JVN what the reasoning was for using a nonagonal frame and swerve drive back in '08. I want to say I remember someone on that team saying it was to make it easier to go through traffic, but can't remember who, or if that was actually what they said.
I would consider it as "ease of getting through traffic" myself--you can use the robot as a wedge to split apart defenders (or move defenders away from the wall) if need be .
Unread 07-11-2014, 08:46
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I thought a main benefit of octagons was to make the robot bigger. Allow wider collectors and such.
Unread 07-11-2014, 09:53
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lap runners in 2008, such as 148, required significantly different strategic design than the "general" robot does. The strategic advantages of round-ish, and more importantly, small for 148 are very different than the drivers behind most hexagonal/octagonal drivebases in 2014.
I don't think you'll see much of a wedging effect, given that bumpers exist.
It does allow more total area, but actually reduces your sidelengths, resulting in smaller under or through-bumper collection mechanisms. Over-bumper size would be determined by the rules of a particular game's maximum size (how far you can exceed bumper perimeter, total cylinder size, etc.).
Unread 07-11-2014, 11:17
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Agreed. I was thinking of something like 1310's double wide disc collector in 2013.
Unread 07-11-2014, 15:37
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
We noticed a wedging effect with our robot this year. The geometry of the octagonal bumpers helped us get into the low goal pocket in situations where I don't think a square robot would have succeeded.
Another advantage of having an angled side is that you can adjust your aim when shooting even with someone pushing on your bumper (that is if you aren't doing a turret on top of swerve).
Unread 07-11-2014, 10:48
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
We used an octagon frame last year to fit our shooter due to our design concept requiring our robot frame to have some extra width in the center. We didn't realize the benefit of getting out of friction pins until later in the season when teams started asking us how our anti-tbone bumpers were working.
You can pickup a little bit of room for widening a collector by doing something similar to this which is what 469 had this past year. If you play around with geometry in the corners you can gain some room but you need to decide if its worth the effort or if its an aspect of your design that needs to be reconsidered.
1058 PVC Pirates 2016 - xxxx
