Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 08-11-2014, 19:05
Re: Gussets
Originally Posted by lamk View Post
Any reason why you don't want to use the VEX gussets. Since you're in Toronto you can go to Pickering to pick it up directly from their warehouse. For our team, shipping is always the issue.
Sometimes, COTS is not the way to go. I know, that's a radical idea. But sometimes, COTS just doesn't fit your needs, and won't be readily adaptable to them either. Which is why most teams like to have some form of machine shop handy...
Unread 08-11-2014, 19:18
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: Gussets
This may go without saying, but I would heavily recommend against Lowes brand steel gussets. Our team used some in our offseason event to attache part of our new super structure and they bend completely out of shape in our first match with them. Anything Vex thickness or above aluminum should do the trick.
