Go to Post FRC is a game of mentors. The best teams are guided by mentors who know how to balance on the knife edge of pushing the envelope and achieving success. - Mr. Van [more]
Unread 08-11-2014, 19:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gussets
Originally Posted by Sohaib View Post
What material would you recommend for gussets
Depends on what we're building. You didn't specify what you're building, or the materials you're using, so it's kind of hard to make a good recommendation. But usually it's a good idea to use a material similar to what your gussetting.
For example, when we make stuff out of 1/16" thick aluminum tubing, we usually make gussets out of 1/16" thick sheet aluminum. Cut to size with a bandsaw or snips, and drill holes for rivets, then clamp to the part and drill a hole for the first rivet, install the rivet, drill the next hole, rivet, etc.
Unread 08-11-2014, 19:50
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Gussets
We have a fairly unique situation (a laser cutter), but we've had success using 1/4" birch plywood for gussets.
It would be easy to make gussets like those on a band saw and drill press instead of a laser cutter.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 08-11-2014, 23:03
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Re: Gussets
We have a shear, a brake, and a finger brake in our shop. Many of our gussets are made from scarp pieces of aluminium as they are needed. It takes just a few minutes to cut, drill, and fold the gusset as needed. Then you put it on the robot and drill robot threw the holes in the gusset and attach.
KF6UZX
