Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 09-11-2014, 01:39
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: pic: Team 2950 Devastators WCD
Originally Posted by Thad House View Post
It looks like you are using shaft collars to hold the wheels on. I would strongly encourage not doing that. Use e-clips, snap rings, or bolts threaded onto the end. shaft collars will slide off almost immediately. Other then that, it looks like a great start.
Well that is slightly embarrassing. On the outer wheels there is suppose to be a bolt at the end. I'll definitely look into using snap rings though. Thanks for the advice!
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
