Go to Post 2010 game piece--- participation medals - johnr [more]
Unread 10-11-2014, 14:46
AdamHeard's Avatar
Lead Mentor
Re: pic: Light Weight Swerve Module
Originally Posted by asid61 View Post
The primary reason reason for out drivetrain failing this year was tension-held bearing blocks on the corners of our WCD. There were two screws going through the bearing blocks on either side of the 2x1 with nuts on the other end. No matter how much we tightened the screws, the bearing blocks would always slip and cause drivetrain failure.After adding some sandpaper-like gripping tape in between the bearing blocks and the 2x1 post-season, we no longer had problems with the drivetrain failing. This is why I always recommend against any kind of friction fits.
Now, the forces are less extreme on the first stage of a transmission, but I still wouldn't do it in the middle of the season.
Ah.
The loads here aren't even comparable.
No slot obviously is more secure, but slots can be used for motor c-c adjustment without issue in FRC.
A nice trick is to angle the slot away from the direction of force (for belts/chain) as much as you can fit. This not only increases your tensioning resolution, but decreases the friction required to hold position.
For gears you actually want to aim at the other shaft, as the forces pushing the gears apart are the lowest of the forces generated in that interaction.
