Go to Post Instant Replay??? AAAAAAUUUUUGGGGGHHHHHH!!! - Bill Moore [more]
Unread 11-11-2014, 09:51
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: GBX-114 improved
Unread 11-11-2014, 09:52
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: pic: GBX-114 improved
Great looking renders! Is that bottom plate the only way it mounts to the frame? How thick is it?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 11-11-2014, 14:25
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
How much does this version weigh with the hardware?
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 11-11-2014, 14:36
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Yes, it only mounts by the bottom. I have it constrained quite securely via the delrin sliders you can see int he back. There are only two, so I might make them bigger.
8.92lbs with the minicim, 6.52lbs without it. The minicim mount isn't shown in this picture, but t's in the final version.
I really dislike how much weight was added by the shifter, so I'm going to mess around with it to try and decrease that.
Unread 11-11-2014, 15:02
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
What is the CIM clearance for the wires?
Also, I'm still confused what the bearing system is on this. Is it held up by the plastic block, or is that just to keep the module from falling out? If not the block, what does hold he robot up?
Unread 11-11-2014, 15:30
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
CIM clearance is 0.625" to the ground, but 0.75" from where the wires come out.
So underneath the bottom plate there is a steel shim. Below that is the large turning gear. This constrains the module in normal, still conditions. To stop the module from jumping out the bottom, there are some delrin blocks that slide on top of the bottom plate. These have a 0.004" clearance to the plate, and they stop the module from jumping out from the bottom. If you download the cad you'll see it.
https://drive.google.com/file/d/0BzU...ew?usp=sharing
Unread 11-11-2014, 19:19
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I'm away from my computer right now.
If I'm understanding corectly, the weight of the robot is siting on a steel shim washer, that is siting on an aluminum turning gear.
If that is the case, I would highly recommend changing it to use an IGUS thrust washer or a bronze thrust washer.
Unread 11-11-2014, 23:56
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Would you know where to source a 3" inner diameter washer, or would I just have to cut one myself?
Unread 12-11-2014, 00:38
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I'm not sure, you might be ablessed to get one from IGUS, but at that diameter, they might be too thick. I would personally recommend the use of a ball thrust bearing.
